![]() Drives: 12' Black Camaro SS/RS Convertible Join Date: Jun 2013
2012 SS BA Speakers
Can someone tell me which speaker size are in the 2012 Camaro Convertible SS/RS BA system? I want to replace all the speakers and amp but want to make sure I order the right size speakers...also what is the best amp that will fit in place of the factory amp?
Thanks in advance
2012 Camaro SS/RS Convertible * Forgiato Wheels 24" front 26" rear * Catback Magnaflow Exhaust with 5" chrome tips * Blacked out emblems * AAC Aqua interior and footwell lights * VIS Terminator Carbon Fiber Hood * Pioneer Double Din/Carbon Fiber Scosche Kit * Oracle Red LED bowtie *
![]() ![]() Drives: 2010 Camaro 2SS/RS RJT, 6speed Join Date: May 2011
pretty sure the fronts are 6.5 inch components with 1" tweets and the rears are 3.5 inch. I think there's a single woofer in there too. Maybe a 10 inch?
If you replace the speakers make sure to replace the amp. I put in a JL XD 400/4 but you need a second one to drive an aftermarket woofer or you can go with one of the bigger amps but you have to mount it elsewhere. I think you can squeeze a JL 600/6 into the factory spot behind the driver side tail light (where the Boston amp is)... Others have gone the Alpine PDX V9 amp also.
2010 Camaro 2SS/RS, LS3 - 6 speed. Mods, Magnaflow exhaust with resonator delete. ******** 12" stealth box subwoofer kit, Kicker 400 mono amp, JL XD 400/4 amp.
Thanks...will the JL 600/6 push both the highs and the sub? I am getting the JL w3 10" sub...do you know if that will fit in the factory sub spot or do I need to get the stealth box?
You may want more than the 200w for the sub. That's why I didn't go with the 600/6 and opted for a two amp system.
I'd suggest the 400/4 and the 600/1
![]() Drives: 2013 Camaro 2LT RS IOM Join Date: Jun 2013
The JL XD700/5 will give you 75w rms x 4 and 300w rms @ 2 ohm for a sub and will fit in the factory spot. 300w rms is a perfect match for the JL W3 just make sure you get the 2 ohm version. JL W3 should fit in the stock spot will a little bit of modification.
#6 |
![]() Drives: 2012 1LT Drop Top Join Date: Oct 2013
The subwoofer is 9" and is mounted in a subframe with the small amp attached that bolts into a larger , (rectangular), opening. Just get the ******** adapter and get a 10" sub and you'll have a simple install with no modifications!
| Tags |
| ba speakers, speakers |
