#1 | |
![]() ![]() ![]() ![]() Drives: 2014 2SS RS Coupe Join Date: Sep 2013
Is this how I should wax my car?
I feel like this will give swirl marks.. |
![]() Drives: Eastbound and Down Join Date: May 2012
I have used that product in the past with great results. If you use a good micro fiber cloth you will not get sworls.
How else would you do it?
Sent from my HTC One using Tapatalk 2
[B]
![]() Drives: Camaro 2010 Join Date: Mar 2010
I heard straight back and forth motions were better than circular motions. True or False? Thanks.
Drives: 2010 Mazdaspeed 3 Join Date: Mar 2012
It doesn't make a huge difference. If you are creating marks of any kind you are doing something wrong. That said, using straight lines would REDUCE the appearance of scratches if you create them.
#6 |
![]() ![]() ![]() ![]() ![]() Drives: 2014 Camaro 1LT/RS Join Date: Sep 2013
Just got to make sure you do that satisfactory head nod into your reflection after you get the high gloss, or else you will get the swirl marks.
Detailing is an involuntary obsession.
#7 |
Drives: Like I Stole It! Join Date: Jun 2009
^ LOL
swirls come from the towel you're using, not the wax. |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 ZL1 1LE Satin Steel Join Date: Jul 2011
Surface prep also.
Ryan
Ryan
2021 ZL1 1LE Satin Steel Metallic Build Page: https://www.camaro6.com/forums/showthread.php?t=632481 |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS/RS - 2004 Silverado Join Date: Mar 2010
I've used spray waxes MANY times on my truck and Camaro. However, they shouldn't used as the ONLY wax procedure on your car. Traditional waxes (either by hand or orbital) will give you better results compared to spray waxes. Spray waxes are great to restore your paint's finish in between traditional waxing.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80 2004 Black Silverado 1500 2WD Regular Cab, Short Bed -5.3 LM7, 4L60E, 3.42, G80 2014 White Caprice PPV -6.0 L77, 6L80E, 2.92, G80 |
#10 | |
