Old 12-06-2013, 04:03 PM   #1
Tonyk88
Drives: 2014 Camaro SS2
Broken rocker arm on 2014 SS/RS
Anyone have a broken rocker arm in just two weeks of ownership or 480 miles? I'm a first time Camaro owner but 2 weeks is just too soon to have issues like this, is this just the beginning?
Tonyk88 is offline   Reply With Quote
Old 12-06-2013, 04:05 PM   #2
RollaMo
RollaMo's Avatar
Drives: 2017 2SS
How high did you rev the engine?
Of course breaking a rocker arm this soon isn't normal.
Hell, I've never broken one. But I don't push it to the red line very often either.
1996 Corvette - LT4
2017 Camaro 2SS
2019 GMC Sierra 2500 HD
2015 Harley Davidson Ultra Limited
RollaMo is offline   Reply With Quote
Old 12-06-2013, 04:11 PM   #3
Tonyk88
It actually happened at a red light, just pulled out of a parking lot for lunch got up to the red light and at a dead stop it just started shaking pretty bad.. When I drove off it was puttin as if it was missing..
Old 12-06-2013, 04:28 PM   #4
RollaMo
RollaMo's Avatar
Drives: 2017 2SS
So, you don't really know for sure that you even have a broken rocker arm.
You haven't pulled the valve cover off to verify this?
Highly unlikely you would break a rocker arm just sitting at a red light.
If you "think" you have a broken rocker arm, I sure wouldn't be driving it any farther.
Get it towed to a dealer. It is under warranty.
1996 Corvette - LT4
2017 Camaro 2SS
Old 12-06-2013, 04:38 PM   #5
caverman
caverman's Avatar
Drives: '69 SS Convertible
That's what warranties are for though. Just because it's new doesn't mean it won't break.
OP....My car is coming on 4 yrs old. I've had a slightly leaking valve cover gasket and a small rip in a rear CV boot. Really nothing to speak of warranty wise.
Build Journal
Old 12-06-2013, 04:59 PM   #6
Tonyk88
Haha guess I should of clarified some details, yes I pulled over immediately and had it towed to the dealer. It took them two days but verified a broken rocker arm, as for the circumstances prior to it happening? Yes at a red light just after start up and it sitting at work for the previous 5 hours.. That's why I'm asking I just feel that shouldn't happen especially on a brand new car. Driving habits over the two weeks were pretty conservative exceeding 100 mph only once for a very short distance and red lining maybe once accidentally and just briefly..
Caverman I agree on just cause it's new doesn't mean it won't break, I just wanted to see if there were any similar occurrences out there.. Good to hear it sounds like a rare happening, thank you all for your replys..
Old 12-06-2013, 05:05 PM   #7
not
Drives: Camaro 2SS/RS
It does happen and indeed, the warranty is like homeowner's insurance, good to have but don't want to use.
I have been in manufacturing all my life. It doesn't even bother me anymore that stuff brand new and costing more than 3 new Camaros come in junk, garbage, don't pass go. Actually if something new runs good initially and a bit afterwards, it is good to go for its useful life, given you maintain it as required.
You will get past this, bet the engineers at Chevy will be poring over this when they go through initial quality metrics next month, ha. As Ricky Ricardo used to say "Got a lot of splaining to do Lucy"...........
Best regards.
not is offline   Reply With Quote
Old 12-06-2013, 05:29 PM   #8
cadyshac
It's in the hole!
cadyshac's Avatar
Drives: '11 2SS L99 SGM, '18 2SS, M6, HWSE
Toyotas break too......
Especially if you accidentally briefly redline them "only once" or drive them 100 mph "for a short distance"
cadyshac is offline   Reply With Quote
Old 12-06-2013, 06:53 PM   #9
caverman
caverman's Avatar
People have different train of thought on babying it the first 500 miles or so and others don't. Me, I just drove it from normal from day one. Never worried about what RPM or MPH or whatever. I did wait a couple months before taking it to the drag strip but that was only because of the weather. I picked up my car in early February and waited until April or so before it saw it's first run down the track.
I will also say that I didn't follow the dealers guidelines of changing the first oil at normal intervals. I changed my oil the first time at about 500 miles. Changed the Trans fluid over to synthetic at less than 1K miles.
Build Journal
Old 12-06-2013, 07:03 PM   #10
2014v6
2014v6's Avatar
Drives: 2014 black 2 LT
Dont the dealer change the oil before it goes to the lot? Like a pdi thing?
Ordered:May 18 2013
2000 status 6-11-13
3000 status 6-12-13
TPW 7-22-13(6-14-13)
3300 status 6-28-13
3400 status 7-18-13
3800 status 7-20-13
4200 status On its way home
6000 status 7-31-13 first camaro ever...
Sold 7-5-14.. thank you oshawa assembly
2014v6 is offline   Reply With Quote
Old 12-06-2013, 07:19 PM   #11
The Stig
knows 2 facts about ducks
The Stig's Avatar
No.
Click to view my build thread
Old 12-06-2013, 08:29 PM   #12
ChrisBlair
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3
So you're worried that the steel parts in your camaro's engine are going to start breaking?
You had a freak, premature failure of a small part. This is not the time to start panicking that your engine is going to fall apart.
Quick story: in 1998 I had a ball joint failure on the highway. Lower ball joint. I had personally replaced all my ball joints two years earlier. In closer inspection of the part, the ball joint itself never failed. The nut stripped out, leaving threads of the nut still on the stud, and the remains of the cotter pin in the cross hole. The nut must have had a bad heat treatment.
That was an Original Equipment Manufacturer (Moog) part for my '70 Buick. It had sat in its original box for decades waiting for me to buy it, and then fail way too early. Flipping lucky I didn't have a bad crash. I also have had valve keeprs on very expensive brand new heads fail within 500 miles- lucky I yanked the covers when I did, I was about to drop three valves!
These failures are very rare, just like your rocker arm failure.
ChrisBlair is offline   Reply With Quote
Old 12-06-2013, 09:19 PM   #13
lugnut65
Drives: 12 2SS/RS 45th L99
I had 307 miles on mine,and was really easy on it Just started it up after sitting for a week,and its started shaking,more than normal Check engine lights came on Took in for service about 6 miles to dealer And........
Broken valve spring on #6 cylinder Wasn't very happy since I haven't really hammered on it Might be the reason I don't want to get a tune or void the warentte Got 2200 miles on it and no problems since,but always in the back of mind
12 RS/SS 45th L99,CAI,AND BORLA CB
70 CHEVELLE SS LSX408
lugnut65 is offline   Reply With Quote
Old 12-07-2013, 01:13 AM   #14
not
Originally Posted by The Stig View Post
No.
Way to go Stig, you smashed the chance for this thread to go 19 pages over changing oil at break-in and what type to use.
How dare you............ha
2014 camaro, 2014 ss, brand new 2014, rocker arm failure
