Old 12-07-2013, 07:03 PM   #1
SnowyCamaro
SnowyCamaro's Avatar
Drives: 2013 Camaro ZL1, 2006 Chevy Equinox
Wiring up Blackberry Music Gateway in Car
So I don't know if many people have seen the new Blackberry Music Gateway, it's a bluetooth music dongle style thing. Essentially it allows me to connect my phone to it and then it has a 3.5mm jack output. I plan on installing it in my 2010 which doesn't have bluetooth. So that once I hop in my car, I can just select "AUX input" on the radio and then my phone is already wirelessly connected to play music.
My main question is, it runs off of a usb cable to power it. I'd like to hide the wires within the car. Is there any usb power adapters to direct wire in out there ? and also where should I wire into for switched 12v power that will have the proper amount of current there to tap into, without blowing any fuses?
If this works well for us with the non bluetooth cars, I'll post up a DIY later on.
SnowyCamaro is offline   Reply With Quote
Old 12-08-2013, 11:14 AM   #2
Old as Dirt
Old as Dirt's Avatar
Drives: 2013 Camaro
They make USB adaptors that plug into your outlet in the console.. and BTW, that is a decent place to draw switched power from also to power your Blackberry Music Gateway....
Old as Dirt is offline   Reply With Quote
bb music gateway, bluetooth, usb power
