![]() ![]() Drives: 2013 Camaro 2SS RS Convt. Join Date: Mar 2011
Polished Strut Tower Brace?
Mine is that dull aluminum and I thought about doing a mirror polish and paint the brackets body color. I was wondering if anyone here has polished their strut tower brace if so, would you mind posting up a picture?
2013 Nickey Stage II Camaro SS Convertible #10.Black w/ Red leather interior. No Weeds Elec. Diverters, CNC ported heads, custom grind cam, upgraded fuel injectors, ZL-1 fuel pump, V-Max ported TB, Red Magnuson Super Charger with rear cog drive, upgraded rear axles good for 1400Hp, 3:45 gears, Tremec 6 spd., Pedders adj. coil overs, Phadt ZL-spec swaybars, 800Hp at the crank, 670RWHP, 613ft.lbs. torq. @ 11lbs. boost. SOLD!!!
SoCal C5 Family Member
Here you go.
Parts Guru Extraordinair.
Drives: '02 SS 'Vert M6 Join Date: Mar 2011
Damn,that's sharp.
Please check out my other hobby ; http://jetphotos.net/showphotos.php?userid=1008
SYBIL
Drives: 2013 2SS/RS, silver ice metallic Join Date: Oct 2012
Thats exactly what I was looking for! Do the ends slide off easy so they can be painted? Did you polish the back side as well?
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
They are welded on... I painted mine. As another option.
![]() ![]() Sent from my DROID RAZR HD using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
#7 |
SYBIL
Mine isnt mirror polished but I have put a little polish to it
#8 |
![]() Drives: cts-v Join Date: Dec 2011
Here is one we did for a customer. Polished center bar with Rally yellow ends.
#9 |
If you polish it an paint the ends as nice as the Rally Yellow one you better upgrade the hardware.
#10 |
That yellow one is awesome! Did you have to remove the "texture" on the mounting brackets before you painted them because they look really smooth.
#11 |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Camaro 45th Anniversary RS Join Date: Nov 2012
Those braces look great, I'm currently in the process of painting mine, when I was painting the ends I knocked it over and messed up the black and had ran out of paint. I have another can coming tomorrow so I have to lightly sand, paint and clear. But heres the process so far:
#13 |
Everyone's on here look sweet! Now I need to get off my butt and do mine! Just one more detail to make the engine comp pop.
#14 | |
