Old 07-19-2009, 01:19 PM   #1
sasquash1984
502 RWHP N/A
sasquash1984's Avatar
Drives: The yeti
2 mtx 10's and apline 500 watt amp
pretty simple set up
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
sasquash1984 is offline   Reply With Quote
Old 07-19-2009, 01:26 PM   #2
ljustin293
ljustin293's Avatar
Drives: 2010 VR CAMARO 2SS/RS
looks good
Old 07-19-2009, 02:16 PM   #3
n-shane@hotmail.com
n-shane@hotmail.com's Avatar
Drives: 2010 MAROOOOOO
clean look hows it sound threw the seats in the trunk?
THIS CAR IS AMAZING!!!!!
n-shane@hotmail.com is offline   Reply With Quote
Old 07-19-2009, 04:53 PM   #4
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
nice..you want more cabin bass?..simply remove the rear speakers..
Old 07-19-2009, 10:51 PM   #5
sasquash1984
502 RWHP N/A
Drives: The yeti
strong bass i have the i pod bass at negative 12 and still hits, i listen to drum and bass, and electronica and rock for the most part. it hits good is all i can say car toys did the install
Old 07-19-2009, 10:52 PM   #6
sasquash1984
502 RWHP N/A
Drives: The yeti
the install was fairly easy the battery is in the trunck for power, then box in trunk, then they have a modulator for the sound spliced in the left rear speaker for the amp and have 1 wire going to the fuse box in the front to turn the amp on.
