Old 12-16-2013, 11:39 AM   #1
rjdapilmoto
DAP-ONE [COTW - 12/23/13]
rjdapilmoto's Avatar
Drives: 2010 - 2SS/RS IOM
Emptying the Elite Engineering Catch Can
I'm getting ready to empty mine for the first time. Do you guys use a vice grip to unscrew the can?
rjdapilmoto is offline   Reply With Quote
Old 12-16-2013, 11:42 AM   #2
13blackLS
13blackLS's Avatar
Drives: 2013 camaro ls; 2005 rx8
Mine unscrews by hand
13blackLS is offline   Reply With Quote
Old 12-16-2013, 11:46 AM   #3
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Just undo it by hand. They can be kinda tough sometimes if you really had it tightened down good. Just be sure you are turning it in the right direction. When putting it back on, just get it snug. No need to really crank it down tight.
Best regards,
Tyler
888-308-6007
Old 12-16-2013, 12:00 PM   #4
NJBourne23
Master of Nothings
NJBourne23's Avatar
Drives: 2010 Chevy Camaro 2LT/RS
Make sure you have some petroleum jelly on the ring which mine came with at least. Helps in the winter and keeps a better seal. Take a pic of what you see. I haven't emptied mine since putting it on a few weeks ago. I don't want to see how much is in there
2010 Chevrolet Camaro 2LT/RS
NJBourne23 is offline   Reply With Quote
Old 12-16-2013, 12:03 PM   #5
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
And don't do it when it's hot or make sure to wear gloves, that thing gets hot as a MF'er
FSP tuned: 377/389
Old 12-16-2013, 02:05 PM   #6
rjdapilmoto
Thanks for the tips, fellas! Now......If I remember correctly, if I am holding the bottom piece, it would be a clock-wise turn to loosen the can.
Old 12-16-2013, 04:23 PM   #7
JDP Sales
JDP Sales's Avatar
True story! I have scorched my hands a number of times!
Yes, looking down on the can, the bottom will spin off clockwise.
Best regards,
Tyler
888-308-6007
Old 12-16-2013, 04:31 PM   #8
wessolbuf1
wessolbuf1's Avatar
Drives: 2014 Camaro 1LE Summit White
True story!!
Ordered 10-1-13
TPW- 10-28-13
Delivered 11-12-13
wessolbuf1 is offline   Reply With Quote
Old 12-16-2013, 06:56 PM   #9
skibik
Guest
Drives: bbbbbb
Empty it often. It is my DD and I still don't put hardly any miles on it I went way too long before emptying mine and it was full of water, well make that a chunk of ice. So it kind of turned it useless. Lesson learned and now will empty it more often, at least every couple weeks to a month at the latest. I went a few months last time and it was way too long.
Dean.
skibik is offline   Reply With Quote
