Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Transmission / Driveline
Old 12-18-2013, 03:37 PM   #1
Iroc2430
Smoke'm if you can
Iroc2430's Avatar
Drives: 2010 Camaro 2SS/RS/LS3/M6
SOLD: FEELER, Hurst Short Throw, White Knob V8-M6 Pattern
SOLD.....I purchased a MGW and this needs to go. I should have the MGW installed this weekend. I have brand new Teflon bushing from Hurst with the O-rings installed, the updated ones, like I said, I never installed them. I made some Delron bushings here at work and used them in place of the Teflon ones. SOLD......
http://www.phastekperformance.com/20...st-3916030.htm
Texas Speed LT Headers with HF Cats, Borla ATAK Exhaust, MGW Short Throw Shifter, ADM CAI with Scoop, Elite Oil Catch Can, Mishimoto Aluminum Radiator, Pedders XA Coilovers, Mantic Twin 9000 Clutch, PFADT Solid Subframe Bushings, PFADT Front & Rear Sways, PFADT Upper Control Arm Bushing, PFADT Trailing Arms/Tie Rods, Whiteline Adjustable End Links, Whiteline Adjustable Lower Control Arms, Pedders Diff Bushings, Line Lock, ACC Side Markers, ACC Reverse Lights, Custom Tune from Nitrous Express.
Iroc2430 is offline   Reply With Quote
Old 12-18-2013, 05:15 PM   #2
usafboy
usafboy's Avatar
Drives: 2010 Silver SS/RS LS3
Does it come with the adapter stick to use the stock knob as well???
2010 Silver Ice Metallic Camaro SS/RS LS3
Mods...so far: resonator/muffler delete, tinted everything, '13 shift knob/boot, bowtie delete, PFADT sway bars, CAI intake, Hurst short shifter, JBA cat deletes, BMR trailing arms/outer bushings/steering rack bushing, Bo White ported TB.
Rhino79 Dyno tuned...405 HP/399 TQ
usafboy is offline   Reply With Quote
Old 12-18-2013, 06:00 PM   #3
Iroc2430
Smoke'm if you can
Iroc2430's Avatar
I need to check later on when I get home to see if I have that in the box. I will get back with you.
Old 12-18-2013, 07:00 PM   #4
Iroc2430
Smoke'm if you can
Iroc2430's Avatar
It does come with the adapter fit the stock grip.
Old 12-18-2013, 08:53 PM   #5
usafboy
usafboy's Avatar
PM sent, very interested.
Old 12-19-2013, 09:09 AM   #6
usafboy
usafboy's Avatar
Payment sent.
Old 12-19-2013, 09:50 AM   #7
Iroc2430
Smoke'm if you can
Iroc2430's Avatar
SOLD to USAFBOY
