12-19-2013, 11:05 PM | #1 |
crazier than a coconut
Drives: 2010 2SS/RS LS3 Join Date: Jul 2010
ZL1 injectors for E85
does anybody know if the ZL1 injector will support conversion on the SS for E85? curious if they run a larger injector. looking at the cost in comparison to the ID850's.
Thanks
12-20-2013, 04:50 AM | #2 |
PHAT B33
Drives: 2012 TF3 Camaro 2SS/RS M6 Join Date: Jun 2012
I believe they are 52 lb, that's what came with my SLP SC kit. It would be close NA, I wouldn't risk it. I ran FIC 60's NA but needed the ZL1 pump and ADM FPCM to make it work. Pop for the ID850's and you'll have plenty of room for the future but plan on FP upgrades at any rate. E85 requires over 30% more fuel.
On corn I'm running out of FP on the Livernois twin but I'm blown at 9 psi on ID850's. Waiting on the Squash returnless fuel system to be released.
12-20-2013, 02:49 PM | #3 |
awesome, thanks for the info. yeah, i plan on staying NA...just love the smell. they've got a decent price for the 850's right now which i want to jump on, but if i can get by with out spending more...then thats what i'd like to do. but i don't want to run the injectors above 80% either.
you think NA that i'll need a FP upgrade? thanks Broke
12-20-2013, 06:48 PM | #4 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
I don't think the spray pattern is optimal when staying NA on those injectors.
12-20-2013, 07:11 PM | #5 |
Drives: 2018 Camaro ZL1 Join Date: Mar 2013
I'm tuned on e85 with id850s with the stock fuel pump. i Haven't had any issues. Longtubes, intake and tune.
12-20-2013, 08:02 PM | #6 |
PHAT B33
I never ran the ID850's NA, had FIC 60's for awhile after being blown. Couldn't go more than 50% E until I upgraded the FP, tried the ZL1 pump, then added the ADM FPCM but still was short. Switched to the Livernois twin and 850's and just making it at 9psi.
The post 1 above this is more relevant to you being NA. You just won't know for sure until you log fuel pressure and IDC.
12-20-2013, 08:02 PM | #7 | |
do you have any before and after numbers on E85? what was your gain?
12-22-2013, 12:04 AM | #8 |
I actually have the flex fuel conversion but unfortunately I do not have any direct comparisons from gas to e85. One of these days I will have to do a comparison just for piece of mind.
12-22-2013, 02:09 AM | #9 |
Drives: camaro turtle Join Date: Nov 2013
LSA injectors spray at an angle, they will not work correctly in a regular intake.
This nick no longer in use. Please direct all future pms to 'Dietcoke'
12-22-2013, 07:13 AM | #10 |
PHAT B33
Typical E85 gains are ~5% NA.
12-23-2013, 01:40 PM | #11 |
Drives: 2010 Camaro SS manual all stock Join Date: Jun 2012
I question buying a zl1 only to lose your warranty by going e85, when you could have bought an ss and installed the appropriate mods for much less
06-30-2017, 01:34 PM | #12 |
04 TERMINATOR
Drives: 2004 COBRA/12 CAMARO SS Join Date: Jan 2017
any issues with that set up thus far boss??? really thinking of doing the conversion and this sounds the most cost friendly set up lol
2004 MUSTANG COBRA PULLIED
UPR O/R X PIPE MAC CATBACK K&N CAI 458 RWHP 485RWTQ 12 LBS 2012 CAMARO SS DYNATECH LONG TUBES CUSTOM X PIPE CAI(UNKNOWN BRAND) 3.91 GEARS 425RWHP/428RWTQ |
07-01-2017, 12:28 PM | #13 |
Drives: 2019 Corvette ZR1 Join Date: May 2017
For NA, the LSA/LS9 injectors will support full ethanol unless you have an extreme 600+ whp setup.
