Old 12-20-2013, 03:02 PM   #1
brettsimons
brettsimons's Avatar
Drives: 2011 Automatic Camaro 2SS
Thinking about Drag Radials...
Hey guys,
So I found a good deal on some Nitto drag radials and C5 Z06 rims but I was just wondering if I need to upgrade anything else in the drive train such as axles when I do? I have the 2011 Camaro SS with 1-7/8th inch headers and 3.91 differential. Just looking for advice so I don't end up having to pay for the very expensive tow truck drive home from the drag strip!
brettsimons is offline   Reply With Quote
Old 12-20-2013, 03:24 PM   #2
GFORCE1320
Drives: 05 GTO
Axles are always a good idea anytime you add drag radials or slicks. It doesnt take much to break stock axles.
Give us a call if you need a set.
Thanks
Chris
GFORCE1320 is offline   Reply With Quote
Old 12-20-2013, 03:27 PM   #3
jvoisel
Drives: 2010 2SS/RS M6
Anything CAN break.. You can upgrade axles, driveshaft, build the trans.. Spend 5k+ plus "just in case" or just fix it if/when something happens.
I'd add the radials and drive it.. I've had radials on my car since I bought it, and just plan to upgrade whatever breaks, as it breaks.
2010 2SS/RS
jvoisel is offline   Reply With Quote
Old 12-20-2013, 04:05 PM   #4
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
With the auto run the stock axles. I run DR & slicks cutting 1.50 to 1.60 on stock diff with 3.91 gears & stock axles. Lost count after 200 passes on them. Don't wheel hop it.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 12-20-2013, 08:22 PM   #5
brettsimons
Very true! And thanks Mr. Nasty that's just what I was looking for since I have an automatic too!
Sent from my Galaxy Nexus using Tapatalk 2
Old 12-20-2013, 10:25 PM   #6
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I probably have around 150 passes on my car, stock axles. I bought some extra stock axles just in case, haven't needed them. I have been running drag radials for a while.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 12-20-2013, 11:38 PM   #7
Merc
In The Circle
Merc's Avatar
Yeah you auto Guy's got it good, not near as hard on stuff as the M6. I'm on my 3rd diff, a stock one, a modified one and now the 12 bolt Hammerhead from DSS. I twisted the outer splines on the stock axels before I replaced the axels and driveshaft with DSS stuff.
Old 12-20-2013, 11:41 PM   #8
Merc
In The Circle
Merc's Avatar
Yeah I bet there is stacks of stock axels for sale on C5 if you look. I have a pair some place.
Old 12-22-2013, 12:08 AM   #9
Medi0cr3
Untamed Performance EPT
Medi0cr3's Avatar
Drives: 2011 2SS
Don't waste your time on the Nitto555R...... They're good for street traction, but there are way better drag radials available. M/T ET Streets for one....
Night Fury Cam
Borla LT Headers and Borla Cat Back ATAK
9in. diff with 4.11's, DSS Axles, and Alum Shaft
Hurst Short-Shifter; Ideal Garage Master Cylinder
H-E Street Slayer Twin Billet Clutch
BMR: Adjustable; Trailing Arms, Toe Rods, Extreme Sway Bar. BMR Subframe Bushings.
Strange Rear Coilovers and mounts
Tuned by Rhino79
Medi0cr3 is offline   Reply With Quote
Old 12-23-2013, 11:14 AM   #10
Steve@SNL/Monster Clutch
Drives: 2014 SS
ET Streets or the Hoosiers, the Hoosiers are the better tire IMHO...
You auto guys have it easy!
Steve@SNL/Monster Clutch is offline   Reply With Quote
Old 12-23-2013, 11:45 AM   #11
H-E
Drives: 2010 zr1 Camaro 2011 vert
Axles are hit and miss.One thing you need to do is load the car on the line,make sure you stall the car before you nail it...When your ready for axles give me a call ill take good care of ya
H-E is offline   Reply With Quote
Old 08-07-2014, 08:08 PM   #12
Snidely Whiplash
Fight Crime, Drive Armed
Snidely Whiplash's Avatar
Drives: '14 2SS Yelo Maro, HD collection
Oh heck yeah. Nailing the throttle from idle will flash the converter quite high due to lack of preload on it. It's kinda like side-stepping a clutch at 4000+ RPM. You WILL break things.
Bring back Sunoco 260 to the local station. Some folks STILL drive L-88s and need the good gas.
Snidely Whiplash is offline   Reply With Quote
Old 08-07-2014, 08:13 PM   #13
1989GTA
Drives: 1989 GTA Trans Am
I agree on the Hoosiers for track only. Et Streets if you are going to be driving on the streets with them.
1989GTA is offline   Reply With Quote
Old 08-08-2014, 10:37 AM   #14
Pro Stock John
Writer
I haven't kept track of how many passes I've made, but it's somewhere between 150-200 on stock axles.
PROJECT HEAVY CHEVY
drag radials, drive train, nitto, upgrage
