Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - California > Local Marketplace
Old 12-21-2013, 03:27 PM   #1
Way Too Fast Motorsports
Way Too Fast Motorsports's Avatar
Drives: 349 Stroker E85 Powered Miata
Service and Install Pricing for Camaro5 Members
Hey guys here is the Camaro5 Member Service and Install pricing. If you have multiple parts to install please contact me for a bundle discount, also if you purchase parts from us you also get either FREE INSTALLATION or discounted install depending on the part.
Also we are an Amsoil Dealer so we stock all their fluids, and that is what is used in all our service packages simply because our customers deserve the BEST.
$50 Oil Analysis through Amsoil (Perfect for Extended Drain Intervals or To Monitor Your Engines Health)
$115 Oil Change with Amsoil Filter (Amsoil 5w-30)
$105 Oil Change with Wix Filter (Amsoil 5w-30)
$75 M6 Transmission Fluid Drain and Fill (Amsoil Synthetic Multi Car ATF)
$50 Rear Diff Drain and Fill (Amsoil Synthetic 75w-90)
Install Prices and Packages:
$100 Intake Install ($50 with purchase)
$100 Catback Exhaust Install ($50 with purchase)
$300 Headers Install ($150 with purchase)
$100 Brake Line Install ($50 with Purchase)
$100 Brake Pad Install ($50 with Purchase)
Add $50 for Rotor Install
$2000 Clutch Install Including Clutchmasters FX100 (Stage 1), Fluids, and Flywheel Resurface
$200 Coilover Install ($100 with Purchase)
$250 Spring/Shock Install ($125 with Purchase)
$150 Sway Bar Install ($75 with Purchase)
$2300 Camshaft Install Parts and Labor Included
$400
30,000-mile Service Package
Due at: 30,000 ; 90,000 Miles
• Change Engine Oil and Replace Oil Filter (Amsoil Signature Series)
• M6 Transmission Drain and Fill (Amsoil Signature Series)
• Rear Diff Drain and Fill (Amsoil Severe Gear 75w-90)
• Lubricate and Inspect Suspension, Drive Line and Steering
• Rotate all Four Tires and Adjust Pressure for Longer Wear
• Inspect Air Filter and Fluid Levels, Top-off as Required
• Inspect Engine Drive Belts and Hoses
• Inspection of Brake System, Clean and Adjust as Required
• Full Inspection of Fuel System
• Replace Fuel Filter, Air Filter and/or PCV if needed
• Service and Clean Fuel Injection and Induction System
• Clean Throttle Body
• Multi-Point Vehicle Inspection
• Free Car Wash with all Service
$2000
60,000-mile Service Package
Due at: 60,000 ; 1200,000 Miles
• Everything in 30k Miles Service Plus
• Replace Timing Chain and Tensioner with C5R Kit
• Replace Oil Pump with Melling Pump
• Replace Front and Rear Main Seal if Needed
• Replace Water Pump
• Replace Thermostat
• Flush Brake Fluid
• Flush Clutch Fluid
• Replace Serpentine Belt
• Replace Spark Plugs
• Coolant Flush
Add Ons:
$250 Camshaft Install (Includes Install of Valvetrain Parts)
Way Too Fast Motorsports is offline
Old 12-21-2013, 06:25 PM   #2
glc55
glc55's Avatar
Drives: 2013 ZL1 Black Camaro
Thxs for the information. Greg
glc55 is offline
Old 12-22-2013, 12:34 PM   #3
Bump to the top!
Old 12-24-2013, 11:35 AM   #4
BUMP to the top happy xmas eve!
Old 12-25-2013, 02:52 PM   #5
Bump to the top Merry xmas!
Old 12-29-2013, 12:01 PM   #6
BUMP TO THE TOP!!!
Old 12-31-2013, 01:11 PM   #7
NYE BUMP Happy New Years!
Old 01-02-2014, 10:30 AM   #8
BUMP it to the top
Old 01-04-2014, 11:53 AM   #9
Saturday BUMP! Just stocked up on oil!
Old 01-09-2014, 08:52 PM   #10
slomaro3.4
slomaro3.4's Avatar
Drives: SS/RS L99 Crew
All the way in Venice beach though...
#YOLO
slomaro3.4 is offline
Old 01-13-2014, 12:01 PM   #11
make it a day trip hang out at the beach while we work on your car!
Old 01-26-2014, 01:07 PM   #12
bump openings next week
Old 01-26-2014, 01:36 PM   #13
sdmaro
Drives: 2011 LS Camaro
which coilovers for the v6 do you carry?
Exhaust: Magnaflow catback/x-pipe, Injen SRI, BBK Headers w/ no cats
Suspension: BC BR Coilovers
Cosmetics: ZL1 front conversion, AAC plasma afterburners 2.0, GFX rear,
Interior: AAC red footwells, ZL1 shifter boot/knob, suede center console
sdmaro is offline
Old 01-26-2014, 05:10 PM   #14
pm sent
