Old 12-22-2013, 11:01 AM   #1
nikos30
HT5 EastSide
nikos30's Avatar
Drives: 2010 Camaro 2LT
Question Passenger seat is stuck
I pull the handle to move it back and the seat doesnt move. It clicks like it usually does, but it doesnt go anywhere.
I can rock it back and forth about a quarter of an inch but its locked in place. I looked underneath when pulling the handle and it looks like the black prong doesn't go down far enough to be popped out of the hole, I think.
How do I go about fixing this?
nikos30 is offline   Reply With Quote
Old 12-24-2013, 02:31 PM   #2
nikos30
HT5 EastSide
nikos30's Avatar
nothing? anybody?
Old 12-24-2013, 02:36 PM   #3
Mean Green Z28
Drives: 2010 2SS
You probably have something like a coin or debris in the mechanism that's not letting it release?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
2010 2SS - CAI Intake, ADM Scoop, RotoFab Washer relo. LT Headers and off-road pipes, X-pipe, Muffler Deletes, ZL1 Spoiler, Technostalgia Tail-lights
'98 T/A (Sold) - Forged 6.0ltr, MS3, P&P'd Heads/Valves, 90MM FAST/TB, Headers, 3" Y-pipe, 4" Mufflex Catback. Koni Adjustables w/GC coilovers (550/175), Strano Sway Bars
'94 Z28 (Sold) ... LS1 swap (basically same setup as the T/A), TH350/3500 stall ... swapped it all into the T/A
-- >> Some of my Projects My Fquick Page
Mean Green Z28 is offline   Reply With Quote
Old 12-24-2013, 02:42 PM   #4
nikos30
HT5 EastSide
nikos30's Avatar
That was the first thing I checked :( there was nothing
Old 12-24-2013, 05:42 PM   #5
mySSt
mySSt's Avatar
Drives: '11 SS M6, '14 SS 1LE, '17 SS 1LE
You can take out the seat without too much trouble. It's just a couple of torx bolts in the rear seat end of the two seat rails. Then slide the whole seat assembly backwards an inch or two to clear the 'hooks' toward the front end of the seat rails. I'd disconnect the battery first, wait about 5 minutes, and then undo the electric connector (for airbag, etc) under the seat. Then you can take the whole thing out of the car and see underneath to hopefully find out what's the issue with it.
All this is not hard unless you have a cross threaded torx bolt like my passenger seat came installed with from the factory!!!
Good luck with finding the issue.
Anyone can drive fast in a straight line, its what you can do thru the curves that matters!
'11 CGM SS M6 ordered in 3/11, '14 BRM SS 1LE from stock in 10/13 & '17 HBM SS 1LE in 11/16 - all from BeckyD!!
mySSt is offline   Reply With Quote
Old 12-24-2013, 11:23 PM   #6
Mean Green Z28
Drives: 2010 2SS
He probably cant move it to even get to the bolts ... I'll look at mine tomorrow and see if I can come up with any more ideas
Old 12-25-2013, 06:54 PM   #7
nikos30
HT5 EastSide
nikos30's Avatar
you guys are the best. and yea I cant move the seat to to get the bolts out :/
Old 12-26-2013, 03:39 PM   #8
Abrahams11SS
Drives: 2013 ZL1 V3RT
I had the same problem.. the dealer fixed it all under warranty for me.
Abrahams11SS is offline   Reply With Quote
Old 01-02-2014, 12:57 AM   #9
nikos30
HT5 EastSide
nikos30's Avatar
my warranty has been over I think... right? I bought it in the end of '09
Old 11-10-2015, 02:44 PM   #10
Justification
Drives: Red 2SS/RS Convertible
Sorry for the Necropost, but I'm having this same problem with my 2011 passenger seat.
Can't see anything in the track. Pulling on the seat adjustment lever does no good, and pushing the seat back forward does no good.
Out of warranty, and I can't see how to get to the back two bolts to remove the seat from the track.
Justification is offline   Reply With Quote
Old 11-13-2015, 02:33 PM   #11
kmarshall2121
kmarshall2121's Avatar
Drives: 2012 45th Anniversary Edition
Damn - how big was she?
kmarshall2121 is offline   Reply With Quote
Old 11-20-2015, 02:46 PM   #12
nikos30
HT5 EastSide
nikos30's Avatar
sorry I am responding so late. I rarely look at the forums anymore.
Here is THE SOLUTION: After checking that nothing is preventing it from sliding. All you have to do is get really mad. Seriously, this worked. Get mad, pull the lever up (nicely), and violently shake the seat until it starts sliding again. That fixed it.
That was my solution and worked instantly. Good luck!
Old 11-20-2015, 02:47 PM   #13
nikos30
HT5 EastSide
nikos30's Avatar
yup I had the same exact problem. Everything looked fine. Do as I said above this post and itll probably fix it
Old 02-25-2021, 01:43 AM   #14
TemplarKnight
Drives: 2012 Chevrolet Camaro 2SS
This is the Necropost to end all necroposts. So I finally got my 5th Gen Camaro that I have been wanting for about 12 years. Have had the car for about 3 weeks and when I first attempt to put something in the back seat, the power tilt gets stuck in the forward position (because I couldn't find the release until it was already completely forward). Then it would not power tilt at all. So I am freaking out that the power adjustment on my new Camaro is broken and I am stuck with the passenger seat tilted forward until I can work out with the warranty company on getting it fixed.
Then I google it and this thread pops up. I shake the passenger seat a bit and BOOM, the power tilt starts working again. So I just necro'd the hell out of this post to say thank you!
TemplarKnight is offline   Reply With Quote
broken, passenger, problem, seat, stuck
