Old 12-22-2013, 09:39 PM   #1
Little Blown Blue
Little Blown Blue's Avatar
Drives: 2010 Blown Blue Camaro
TVS 2300 intercooler leak!
So I just purchased this car. It had an aftermarket TVS2300 in it. After driving it for a few days I discovered it has a coolant leak which I determined could only be entering the intake through an intercooler leak. Now the question is where? I've determined there could only be two possibilities: 1) the actual intercooler is cracked and leaking; or 2) either the inlet or outlet tubes where there are rubber grommets.
Mind you it's a small leak. However sometimes after the car sits for a while coolant builds up in the cylinder and give me a shitty startup as it blows out the coolant.
Any ideas???
Little Blown Blue is offline   Reply With Quote
Old 12-22-2013, 09:47 PM   #2
Anythingfast954
Drives: Camaro ss rs/m6
FLdrummer had that problem,I believe Lashway checked the intercooler and found a leak.
Try contacting Either one of them and they could steer you in the right direction.
Anythingfast954 is offline   Reply With Quote
Old 12-22-2013, 09:48 PM   #3
Little Blown Blue
Thanks...
Old 12-22-2013, 10:18 PM   #4
Anythingfast954
Originally Posted by Little Blown Blue View Post
Thanks...
Anytime....
Old 12-22-2013, 10:44 PM   #5
RankSS
Drives: 2010 Camaro SS
I would be careful with that. There is a possibility of hydro locking a cylinder causing a bent rod.
Does not take a whole lot of coolant being sucked in to cause this.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
RankSS is offline   Reply With Quote
Old 12-22-2013, 10:57 PM   #6
King Nothing
Turning wrenches
King Nothing's Avatar
Drives: 2011 Camaro SS By Berger 11BC21
If all you do is bend a rod when you hydro lock an engine your lucky. Most have a rod fly out the side of the block . . . ask me now I know
Sold-2006 Pontiac GTO
M6 1 of 475
353rwhp 353rwtq
Sold-2000 Camaro SS A4 Hardtop #867 of 8913
1 of 103 Bright Rally Red Hardtop SS A4 in 2000
1 of 25 and only SIM Camaro By Berger in 2011 year, 2011 Camaro 2SS/RS M6 By Berger #11BC21
King Nothing is offline   Reply With Quote
Old 12-23-2013, 05:03 PM   #7
Little Blown Blue
Originally Posted by 130R View Post
How do you know coolant is leaking into the cylinders?
There's been times that lots of blue smoke comes out the tail pipes then clears up. Also has given me crapy rough starts... Hydrolock.... its happened to be before on another car i had...
2010 2SS
TVS2300
Full exhaust
Full suspension
20" Vossen VS2's
Pirelli P-0's
Old 12-23-2013, 05:36 PM   #8
TinyToasta
TinyToasta's Avatar
Drives: way too fast....
Did you check your coolant reservoir to make sure you're definitely having an IC leak?
custom build forged LSA, 379ci, TVS2300@15psi, 696rwhp/688ft-lbs, built by DH Individual, Customkingz, tuned by Jannetty Racing
JRE rough idle cam, JRE ported lower intake manifold, OD cog drive, 6% OD crank pulley, ported ls3 heads, NW102mm TB, 1/2'' RDS spacer, IW 8-rib drive
Pfadt Cradle Bushings, Arms & Rods, Pedders Supercar w/FE4 conversion, ZL1 sways, HE Twin Carbon Street Slayer, ZL1 Rear End (3.73)
CTS-V Brake upgrade, Street: 22'' Vossen CV1, Strip: 18'' Forgestar F14 on MT Street Radials
TinyToasta is offline   Reply With Quote
Old 12-23-2013, 05:39 PM   #9
Piccione Performance
Piccione Performance's Avatar
Drives: 2010 2ss/rs & 2014 Stingray
Coolant is not blue smoke on start up, oil is. Coolant burning is white smoke.
Piccione Performance is offline   Reply With Quote
Old 12-23-2013, 06:01 PM   #10
BlownSS
BlownSS's Avatar
Drives: 2010 Camaro SS/RS
I have the same supercharger and it is well documented that these are prone to leak from the valley plate. there was an error in the initial and even the second revisions but they have the issue fixed. Look on the passenger rear of your supercharger and see if there is a small oil leak...........Not saying this is your problem but it has been for many people. You can call Magnuson and they will likely send u a new valley plate but will not reimburse you for labor.
2010 IOM SS/RS LS3, Hennessey HPE550 Polished Magnuson TVS2300 Supercharger. 3.4 Pulley. Kooks long tube headers / high flow cats. GHL Full exhaust. ZL1 Fuel Pump/ADM FPCM. MSW Bap. JRE ZL1 Race cam with new springs/pushrods/Trunion Upgrade. FIC 850cc injectors. ZR1 Map sensor. CAI Induction. JRE Tune.
BlownSS is offline   Reply With Quote
Old 12-23-2013, 06:37 PM   #11
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
I guess you can say I got pretty lucky!...
http://www.camaro5.com/forums/showth...=283627&page=2
I suggest that anybody who buys a TVS2300 kit (especially a used one) test the heat exchanger for leaks or you may have to go through what I did: https://www.facebook.com/media/set/?...0303405&type=1 ...And that's if you don't blow your motor first!
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq
fldrummer is offline   Reply With Quote
Old 12-23-2013, 06:40 PM   #12
UNRIVALED SS
UNRIVALED SS's Avatar
Send a message via Yahoo to UNRIVALED SS
Blue smoke on startup is usually valve guides or seals. While the car sits a small amount of oil leaks past the seals drips onto the tops of the pistons or sits on valve and is sucked in at startup. Usually clears up quickly. How many miles are on the motor? I'm guessing it's an OEM engine? Is it using any oil?
UNRIVALED SS is offline   Reply With Quote
Old 12-23-2013, 06:46 PM   #13
fldrummer
"Black Ace"
fldrummer's Avatar
He PM'd me and said that's how he came to that conclusion--'sounds like the same issue I had.
Old 12-23-2013, 07:08 PM   #14
Nutro
Nutro's Avatar
Drives: 2011 2SS Synergy Green
Oh damn I didn't there was a known issue with leaks.
L99 With a Maggie
Nutro is offline   Reply With Quote
