Old 12-23-2013, 07:07 AM   #1
Kiteboarder85
Kiteboarder85's Avatar
Drives: 2018 SS - 2015 SS 1LE - 2013 SS
Burnouts in auto SS drag
How are drag cars doing their burnouts- are they using their brakes and applying the accelerator?
I'm afraid of ruining my brakes or other components by doing this. Any thoughts? My SS isn't a drag car but will be at high hp soon.
Thanks all. And please don't make this a "you should have gotten a stick" thread. There are reasons why I have an auto due to a repeated broken wrist/arm.
Billy B.
Current: 2018 Hyper Blue SS
Kiteboarder85 is offline   Reply With Quote
Old 12-23-2013, 07:13 AM   #2
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Line lock if you want to toast the tires.....I do mine from a slow roll
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 12-23-2013, 07:20 AM   #3
40years
40years's Avatar
Drives: 2016 CAMARO 1SS Hyper Blue Met.
Apply the brakes (not hard) and them give it a pretty good amount of gas. Give it more brake or gas as needed to keep the tires spinning. When you feel they are hot enough, let off the brake and give it more gas. Let off the gas when you feel the tires start to grab. Stage and hang on.
proud member "club elite" # 89
40years is offline   Reply With Quote
Old 12-23-2013, 07:22 AM   #4
Kiteboarder85
Can you advise on what Line Locking is?
Billy B.
Old 12-23-2013, 07:24 AM   #5
Kiteboarder85
I've done this a couple of times last year with this method which seems to work best. How bad is it for the car? Which parts will be taking stress from this where I should be keeping an eye on for safety?
Appreciate the info!
Billy B.
Old 12-23-2013, 07:27 AM   #6
hunter1660
hunter1660's Avatar
Summit racing sales them.....it's a device that holds the front brakes locked while freewheeling the rear until you release a switch...it's what's used at the dragstrip
Old 12-23-2013, 07:34 AM   #7
Black 13 Maro
Drives: 13' Black 2SS/RS
This is what you need to do it without wearing out your rear brake pads prematurely.
http://www.texas-speed.com/p-19-sjm-...-lock-kit.aspx
Black 13 Maro is offline   Reply With Quote
Old 12-23-2013, 07:34 AM   #8
Kiteboarder85
Thanks! I'll check this out. Is it a seperate setting or will everyday driving be affected by this?
Billy B.
Old 12-23-2013, 07:39 AM   #9
Kiteboarder85
Perfect! I don't know what I would do without Camaro5. This is like the holy grail for new enthusiasts!
Billy B.
Old 12-23-2013, 08:28 AM   #10
elarson5757
Obsessed and Loving It...
Drives: 2013 1LE-SS
Billy,
I've got one on my manual car as well. Mind you I don't race it but that doesn't mean I don't need to occasionally "heat" the tires.... LOL
I bought the Hurst. Only key thing to remember is that you will need to bleed (or have them bleed) the brakes after install. Also for some reason I had a ton of trouble getting fittings to stop leaking after the install at the distribution block. Guy I had finally deal with it when I couldn't said he has had trouble on every fifth gen he has had a brake line off with the same issue.
elarson5757 is offline   Reply With Quote
Old 12-23-2013, 08:41 AM   #11
40years
40years's Avatar
Nothing to worry about, really, until you get your higher horsepower. Then you will need to consider upgrading axels and such.
Old 12-23-2013, 09:39 AM   #12
ChrisBlair
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3
manual trans arguments are out of place in your scenario in any case.
ChrisBlair is offline   Reply With Quote
Old 12-23-2013, 09:52 AM   #13
Kiteboarder85
What do you mean? Are the above opinions just for manual?
Billy B.
Old 12-23-2013, 10:36 AM   #14
Wolvie70
Wolvie70's Avatar
Drives: 2016 2SS, Summit White, A8, NPP
He is saying that doing a burnout like you are suggesting is the same for a manual or auto. Sure you rev it up and dump the clutch but to do a burnout at the drag strip the lifelock is nice.
Wolvie70 is offline   Reply With Quote
