Old 12-23-2013, 05:27 PM   #1
steven2680
Drives: ss beast
best aftermarket intake manifold for ls3
What's sup guys what's the best aftermarket intake manifold out there from turbo to procharger setup
steven2680 is offline   Reply With Quote
Old 12-23-2013, 05:34 PM   #2
BlaqWhole
Drives: 2017 Camaro ZL1 A10
I'd say FAST so far offers the best gains. But a cheaper route is to get your stock manifold ported. The gains from that are slightly less than the gains from a FAST. Ported is an insignificant amount less gains but you'll save hundreds.
BlaqWhole is offline   Reply With Quote
Old 12-23-2013, 06:01 PM   #3
45thCAMARO 2SS/RS
xquest91x
45thCAMARO 2SS/RS's Avatar
Drives: 2012 45th Anniversary 2SS/RS
Just use stock manifold and get it ported. Way cheaper $$$$ like he said^^
2012 45th Camaro 2SS/RS LS3
Driver Mod: Stage 5
Full Bolt-ons + Tune •418RWHP/420RWTQ•
H/C + Bolt-ons + Tune •485RWHP/435RWTQ•
Full BMR Stage 2&3 Suspension
3.91 1LE Gear Diff Swap
MGW Short Throw Shifter
45thCAMARO 2SS/RS is offline   Reply With Quote
Old 12-23-2013, 08:24 PM   #4
steven2680
Drives: ss beast
I seen holly have a nice 1
Old 12-23-2013, 08:34 PM   #5
62nalide
62nalide's Avatar
Drives: 2013 SS
Stock ported one.
Holley If you have a big cube motor or aftermarket hood.
62nalide is offline   Reply With Quote
Old 12-23-2013, 08:37 PM   #6
steven2680
Drives: ss beast
Whats the price for the stock intake ported go for
Old 12-26-2013, 10:50 PM   #7
DieselMD @ Futral
DieselMD @ Futral's Avatar
Drives: G8
Porting the stock intake will gain almost nothing. However, it can have a modification done that will pick up power. Rhino79 and Rick Crawford do them for sure.
DieselMD @ Futral is offline   Reply With Quote
Old 12-26-2013, 11:42 PM   #8
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
A stand-alone ported intake manifold probably won't do much. It does however, provide "extra" gains to other upgrades (CAI, ported throttle body, cam, headers, etc).
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 12-26-2013, 11:50 PM   #9
Chevrolade
Drives: 2010 2SS/RS
Fast 102 here
Chevrolade is offline   Reply With Quote
Old 12-27-2013, 12:22 AM   #10
LS3 SS
Drives: 2010 Cyber Grey Camaro SS (LS3)
This.
LS3 SS is offline   Reply With Quote
Old 12-27-2013, 02:31 AM   #11
timtoolman24
timtoolman24's Avatar
Drives: 2012 LS3 2SS/RS
Or go full custom!!!
timtoolman24 is offline   Reply With Quote
Old 12-27-2013, 08:47 AM   #12
steven2680
Drives: ss beast
That's nice whats the price on that
Old 12-27-2013, 09:42 AM   #13
BlaqWhole
Custom intake manifolds are expensive and not worth the price when used on a stock motor. They are more for big cubes and/or high boost...or car shows. And even then they will still be within the gains of a FAST intake. I've seen some custom intakes priced over $3,000. Your best bet is to go ported. If you can find a good deal on a used FAST, then I would go that route.
Old 12-27-2013, 10:00 AM   #14
steven2680
Drives: ss beast
Well I have to install the cam and keep buying other things and a procharger but that's later on the year
