Old 12-24-2013, 01:03 PM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
Night Fury push rod length
I ordered a Night fury cam kit. I ordered 7.400" pushrods but received 7.425" rods. are these the correct rod length for this cam. stock ls3
JCunningham is offline   Reply With Quote
Old 12-24-2013, 01:21 PM   #2
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
Why are you pulling your heads off just for a cam swap? The heads dont need to come off therefore you dont need to replace your head gaskets.
Some other knowledgeable person here should know more about the timing chain..im not sure on that one.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
Old 12-24-2013, 01:28 PM   #3
JCunningham
Drives: 2017 2SS M6
theses are not head gaskets its a timing cover and water pump kit
http://shop.advanceautoparts.com/buy...tcs-45993.html
Old 12-24-2013, 01:56 PM   #4
chevybowtie
Drives: 2010 Camaro
Unless you milled your heads. I believe it is 7.425". That is what my is.
chevybowtie is offline   Reply With Quote
Old 12-24-2013, 01:58 PM   #5
JCunningham
Drives: 2017 2SS M6
ok thanks. stock is 7.400 but with this cam 7.425 is correct for the Night fury cam then?
Old 12-24-2013, 02:09 PM   #6
chevybowtie
Drives: 2010 Camaro
You got it...
Old 12-24-2013, 02:11 PM   #7
Bo White
Bo White's Avatar
Some run 7.400 and some run 7.425 just have to measure and see.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 12-24-2013, 02:34 PM   #8
JCunningham
Drives: 2017 2SS M6
just got a call from Lethal everything is taken care of. There fast. I figured I wouldnt hear anything until after christmas. No got a call 30 min after I sent the email.
Old 12-24-2013, 07:53 PM   #9
Lethal Racing
Lethal Racing's Avatar
Drives: LSx Performance Specialist
Glad we could get you taken care of. Sorry for any confusion. Glad We could get your order corrected for you.
Shawn
Lethal Racing is offline   Reply With Quote
Old 12-24-2013, 11:36 PM   #10
SolomonAKOO
SolomonAKOO's Avatar
Drives: 2011 2SS/RS
So what's the length for stock heads?
1 7/8" TSP headers straight piped, Custom Tick Performance cam w/ supporting mods, 1" BMR springs and other BMR suspension mods. Tuned with HPtuners by Matt@FSP
SolomonAKOO is offline   Reply With Quote
Old 12-25-2013, 09:11 AM   #11
James720SS
James720SS's Avatar
Drives: 2010 SS
I used 7.400 with my Night Fury cam. It's a ls3
James720SS is offline   Reply With Quote
