Old 12-26-2013, 04:14 PM   #1
kwamonster
Drives: 2010 IOM SS/RS
Unhappy BBK 102mm Throttle body Engine Power Reduced!!!
Today I installed a BBK 102mm throttle body on my 2010 ss A6 and i went to start it up and engine power reduced came across the dash and all the power was gone. Do i need to tune it to get more fuel or is something wrong witht he TB or did i do something wrong on the install?
kwamonster is offline   Reply With Quote
Old 12-26-2013, 05:09 PM   #2
SPOOKYGUNNER
ROCK
Drives: 2013 ZL-1 TRIPLE BLACK VERT
HAVE YOU TALKED WITH B.B.K. TO GET ANY FEEDBACK?
SPOOKYGUNNER is offline   Reply With Quote
Old 12-27-2013, 09:42 AM   #3
Matt@510
Drives: c6 vette cam & full bolt-ons
yes you need a tune if you went from a 90mm throttle body to a 102mm. you just drastically changed the charistics of how the air enters the engine and the amount.
Matt@510 is offline   Reply With Quote
Old 12-28-2013, 11:46 AM   #4
snapp32e
snapp32e's Avatar
Drives: '81-Z28/'07-Tundra/'12-ZL1/'13-Jeep
The throttle response is totally worth the tune. I went 102 after much consideration along with a pile of other goodies. The throttle response is amazing now. So much snap.
ZL1 #612
snapp32e is offline   Reply With Quote
Old 01-01-2014, 03:08 AM   #5
DESERTDOG
DESERTDOG's Avatar
Drives: 2012 ZL1 M6 Summit White
Dyno tune it...just throwing on parts, especially fuel/air delivery parts will confuse your ECM program...will pull the timing out of each cylinder, and she will run way lean...have to tell the fuel injectors to squirt in more fuel to mix with all that air you just let in.
Parts alone don't make horsepower in these cars. A delicate balance of timing, fuel delivery, exhaust scavenging, engine temperature, and of course fuel quality, all need to work together to make big power.
DESERTDOG is offline   Reply With Quote
Old 01-01-2014, 03:29 AM   #6
Fallout
Mid Florida Camaro Club
Fallout's Avatar
Drives: 2012 Camaro SS Ashen Gray
Stock manifold? I didnt think the 102mm fit without mass material removal from the intake or a fast 102.
ECS 1500 supercharger blacked out, Alkycontrol, Livernois Duel Pumps, PRC 255cc aftermarket heads, FSP cam, DSS 9" with 3.55, ARH headers, magnaflow exhaust, Century Level 5 4l80
741 RWHP and 602ft-Lbs
Built By Florida Speed and Power
Coming soon YSI and to the moon
Fallout is offline   Reply With Quote
Old 01-05-2014, 09:34 AM   #7
Craig B
Craig B's Avatar
Drives: 2013 1LE
Would like to know this as well?
Craig B is offline   Reply With Quote
Old 01-05-2014, 10:25 AM   #8
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
it says on the BBK website that a 1/4" adapter plate is included with the 102mm TB.
http://www.bbkperformance.com/produc...ttle-body.html
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 01-05-2014, 11:39 AM   #9
DrkPhx
DrkPhx's Avatar
You definitely need to tune for a TB that big. There are a couple of ETC tables that need to be adjusted along with a few MAP/MAF diagnostic parameters.
Old 01-05-2014, 11:40 AM   #10
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
The 95mm looks interesting as well
Trackman is offline   Reply With Quote
Old 01-11-2014, 02:40 PM   #11
snapp32e
snapp32e's Avatar
Ya tune for sure. No question. And yes, ported the blower snout or else your not getting the most out of the TB.
ZL1 #612
Old 01-16-2014, 04:59 PM   #12
Jason@Phastek
Jason@Phastek's Avatar
Drives: 2010 Camaro
Send a message via AIM to Jason@Phastek
Here are some shots of the 102mm BBK Throttle Body.
Jason@Phastek is offline   Reply With Quote
Old 01-21-2014, 05:30 PM   #13
Mike TexaSS
Drives: 454 LS7 Camaro SS
But does it slam shut under boost?
Mike TexaSS is offline   Reply With Quote
Old 01-21-2014, 08:19 PM   #14
Frans96ss
Frans96ss's Avatar
Drives: 96SS
Give us a call. We can tune it for you. Althought i have never used a BBK 102TB i wouldnt think it would put it into reduced engine power.
Put the stock TB back on and drive it up and we can switch it here and see if its the TB or the tune.
Frans96ss is offline   Reply With Quote
bbk, power, reduced, throttlebpody
