Old 12-26-2013, 04:16 PM   #1
kwamonster
Drives: 2010 IOM SS/RS
Unhappy BBK 102mm Throttle body Engine Power Reduced!!!
Today I installed a BBK 102mm throttle body on my 2010 ss A6 and i went to start it up and engine power reduced came across the dash and all the power was gone. Do i need to tune it to get more fuel or is something wrong witht he TB or did i do something wrong on the install?
kwamonster is offline   Reply With Quote
Old 12-26-2013, 04:19 PM   #2
STSL
Drives: 2010 ZR1 Camaro
Well you need to have the car tuned for the 102 but it shouldn't be going to reduce power mode. Disconect the bat and try again
STSL is offline   Reply With Quote
Old 12-26-2013, 04:40 PM   #3
62nalide
62nalide's Avatar
Drives: 2013 SS
It'll go away, but I would tune a 102 TB to act and perform right.
62nalide is offline   Reply With Quote
Old 12-26-2013, 05:03 PM   #4
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
A 102tb on a stock intake manifold that is 90mm?
Pics?
Old 12-26-2013, 05:33 PM   #5
kwamonster
Pics?
here is a pic if you are curious. It was a gift i was expecting the 95mm but was told the 102mm would work still. i have no problem getting a tune but i would like to be able go faster than 12 mph i pulled the battery and now im getting the code p2176 idle not learned any ideas
Old 12-26-2013, 06:27 PM   #6
kwamonster
I got it fixed guys it was a dumb mistake, the gear was not in it thus idle was not detected. And i will get it dyno tuned soon right now i have the diablosport trinity and have modified the diablo settings!
Old 12-26-2013, 07:25 PM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
I hate to sound negative but it could be a 202mm TB on a stock intake and it will still be a 90mm opening. I just don't see how it will increase performance, even though a FAST 102 intake and a FAST 102 TB won't make that much difference on a cam only car.
Wht are your mods?
Old 12-26-2013, 07:46 PM   #8
steven2680
Drives: ss beast
88 y u have to be so negative lol
steven2680 is offline   Reply With Quote
Old 12-26-2013, 07:53 PM   #9
BlaqWhole
Drives: 2017 Camaro ZL1 A10
It isn't negativity, what Litle said was the truth. And it is better that someone speaks the truth than just nods their head in agreement. That extra size difference won't help out at all on a stock manifold. Here I am sticking up for him, and I can't even stand him, lol!!
BlaqWhole is offline   Reply With Quote
Old 12-26-2013, 08:06 PM   #10
steven2680
Drives: ss beast
Lol iam just talking sh..t but I hear u truth some time hurts lol
Old 12-26-2013, 08:23 PM   #11
kwamonster
Wht are your mods?
I definitely agree with you, that's what forums are for, Im not sensitive. I believe i stated it earlier it was a gift so i put it on, but not im going to buy the fast 102mm intake and possibly a couple other things. Im open to suggestions and all opinions.
Old 12-26-2013, 08:38 PM   #12
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
dont uhave to take the tb apart and use ur motor type deal. id say u got that off a tooth. i seen this problem before happen.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 12-26-2013, 08:46 PM   #13
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
I think technically the LS3 intake opening is 93mm but that 102mm TB has got to be hurting vs helping. Take the stock TB with you when you dyno. Since it only takes about 15min to change you can know for sure.
On a side note I would like to see a 95mm TB on the stock LS3 IM. Would like to know if there is a smooth transition from TB to IM or if there will be turbulence because of the 2mm difference.
Old 12-26-2013, 09:12 PM   #14
kwamonster
Yea the 95mm is the one i wanted originally so yea ill take the stock one with me as well and ill be sure to post the results in this thread
bbk, enginepowerreduced, throttlebody
