Old 12-26-2013, 10:41 PM   #1
camaro2lt
camaro2lt's Avatar
DIY:V6 Brakes to 4 Piston Brembo Calipers
Hey guys here is a DIY to add SS brembos to a v6
#1 jack your car up and don't forget to use jack stands!!!!
2 Remove wheels
3 Remove bolt that holds brake line to the caliper (green paint is on it in the pic)
4 Remove U clip where the rubber brake line goes into the plastic line. (see pic 3)
5 Remove 10mm bolt hat holds brake line to the strut assembly (pic 4)
Old 12-26-2013, 10:45 PM   #2
camaro2lt
camaro2lt's Avatar
Step 6! Remove 10mm Bolt from brake line hold assembly (below pic)
---7! Place ratchet on top of the line and unscrew the line from the rubber part of the line. (pic 2)
Your Stock line is removed!
I replaced mine with Goodridge stainless steal lines
Old 12-26-2013, 10:52 PM   #3
camaro2lt
camaro2lt's Avatar
Bolt in your new line using the steps to remove the stock line!
Next is to remove the caliper. It is held in with 2 bolts! Remove the 2 bolts and the caliper will be removed!
Next slide your rotor off....there will be a star screw holding it in!
Your rotor is off and you are down to the wheel hub! I always like to clean the rust off the hub using a dremel.
Old 12-26-2013, 10:59 PM   #4
camaro2lt
camaro2lt's Avatar
Install your new brake rotor!
Install new caliper
Tighten 2 bolts and use blue loctite!
Attach new brake line to new caliper
make sure everything is tight and not loose
Bleed brake system.......there are 2 bleeding valves on the calipers...bleed them until you have all of the air out of the system and you do not see any bubbles!
Install wheel Torque wheel to 100foot lbs
Go test brakes and brake in your new pads!
Old 12-27-2013, 12:08 AM   #5
CamaroLS
CamaroLS's Avatar
Drives: 2014 Blue Ray Met. Camaro 1SS Vert
Looks great!! Done mine a mouth ago. Love 'em
CamaroLS is offline   Reply With Quote
Old 12-27-2013, 03:53 PM   #6
verboten
Drives: Black
The caliper bolts are on tight! I needed long breaker bar.
verboten is offline   Reply With Quote
Old 12-29-2013, 12:34 AM   #7
intensifi
Drives: '12 2LT Convertible
Caliper bolts are torque to yield. You need to torque them to a specific value then add 90 degrees.
The brake lines also have specific torque requirements as well.
Here are the torque settings for the front brakes (from ZL1 brake upgrade installation instructions):
Front rotor screw (torx): 10 NM [ 89 LB IN ] <- inches, not feet
Caliper bolts: 40 NM [ 30 LB FT ] + 90 degrees
Brake line to Caliper: 40 NM [ 30 LB FT ]
Brake line to Interior brake line: 16 NM [ 12 LB FT ]
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 12-29-2013, 09:09 PM   #8
01pewterz28
#TeamBeckyD
01pewterz28's Avatar
Nice write up for those who have not done this mode. I did mine almost 4 years ago I love mine.
#TeamBeckyD
**FIFTY HBM 2SS VERT**
Old 12-29-2013, 11:46 PM   #9
camaro2lt
camaro2lt's Avatar
Its a nice and a not too expensive mod!
Old 02-11-2014, 11:05 PM   #10
NOVAK
NOVAK's Avatar
Drives: 2015 ZL1
What about the rear brakes? I'm picking up a set of red 1LE Brembos and have read that the V6 dust shield need to be replaced with V8 dust shields on the rear. Anything else to be concerned about? Thanks for the write up as it answered a lot of questions for me!
NOVAK is offline   Reply With Quote
Old 02-11-2014, 11:14 PM   #11
CamaroLS
CamaroLS's Avatar
You can change them but a pain to do. Most of us just trimmed the V6 shields and painted the raw edges with black paint. Other than that fits and works great!
Old 02-11-2014, 11:21 PM   #12
CamaroLS
CamaroLS's Avatar
Here are some spec charts for the SS.
Old 02-14-2014, 10:09 AM   #13
01pewterz28
#TeamBeckyD
I trimmed mine and painted the edges out no biggie.
#TeamBeckyD
Old 02-14-2014, 10:10 AM   #14
01pewterz28
#TeamBeckyD
My other suggestion if you are going to do this replace the OEM pads with Hawks Pads the brake dust will kill ya.
#TeamBeckyD
