Old 12-28-2013, 07:46 PM   #1
ssgirl2010
Drives: 2010 Silver 2SS/RS Camaro
injector info?
Does anyone know the injector info on the FAST injectors? Like Injector flow rate at 58psi, injector voltage offsets, short pulse adder, minimum injector pulse width, etc.
ssgirl2010 is offline   Reply With Quote
Old 12-28-2013, 07:55 PM   #2
BLACK10
BLACK10's Avatar
FAST often does not have injector data. We do not use them for that very reason.
Old 12-28-2013, 09:26 PM   #3
ssboy2010
Drives: 2010 Chevrolet Camaro 2SS / Silver
What size injected u use
ssboy2010 is offline   Reply With Quote
Old 12-28-2013, 10:09 PM   #4
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Play with this:
http://www.witchhunter.com/injectorcalc1.php
Old 12-28-2013, 10:42 PM   #5
Bo White
Bo White's Avatar
There are a lot of tuners that use FAST injectors and there are a lot that don't lol. I for one will be putting FAST 85lb injectors in mine when I do my cam swap.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 12-28-2013, 10:51 PM   #6
white ZL1
Drives: none
Originally Posted by blake-b View Post
How does that help get the required injector data?
white ZL1 is offline   Reply With Quote
Old 12-28-2013, 11:17 PM   #7
blake-b
blake-b's Avatar
Drives: 2009 ZR1
It doesn't. I misunderstood the your post and thought you were wondering what size injectors to get...
FIC is another popular brand to look at if you decide not to go with FAST.
Old 12-28-2013, 11:42 PM   #8
ssgirl2010
We have FAST, our tuner needs the injector info. We got them before telling him which ones we were getting because we heard good things about them.... but now we have to get the injector info before he will tune it because he says they are hard to tune without the info.
Old 12-29-2013, 02:11 AM   #9
Scourage
Syntax Error
Scourage's Avatar
Drives: 2010 Camaro 2SS/RS
I gave up on them when I had to go to larger injectors, Comp Cams/FAST tech support told me they have no data for their injectors. It cost more, but I went with ID.
Scourage is offline   Reply With Quote
Old 12-29-2013, 04:46 AM   #10
Bo White
Bo White's Avatar
A lot more. My tuner doesn't even flinch at the words FAST injectors. He was the one that reassured me they are good injectors and that he's tuned them in a wide variety of GM vehicles.
Totalled:
Old 12-29-2013, 09:36 AM   #11
Unreal
Drives: 2006 Z06
A lot of tuners just plug in the size and go. You may never know what your missing but I've seen people swap to IDs and be amazed at how much better the car drives around town. WOT typically isn't an issue but part throttle, idle, tip in, etc are much better with correct info.
Nick
Corvette Z06 -1200ish rwhp
Old 12-29-2013, 10:13 AM   #12
Bo White
Bo White's Avatar
Im sure tuning with info is easier but like my tuner said you still have to do tweaking in each individual cell on the map. Its just being thorough on the tune that makes the difference on not having data with the injectors.
Totalled:
Old 12-29-2013, 10:18 AM   #13
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
FIC provides data, it's kinda close. ID data is very close. Easy to dial in.
Iam Broke is offline   Reply With Quote
Old 12-29-2013, 10:21 AM   #14
Unreal
Drives: 2006 Z06
I disagree. Either way you should hit all the cells but is he varying voltage on the car to adjust fueling from 11-15V? Without the data fuel could be spot on at 14V and off at 13V. That is why there is voltage offset data. Things like that don't matter if he tunes every cell.
Nick
