SYBIL
Drives: 2013 2SS/RS, silver ice metallic Join Date: Oct 2012
True dual vs x pipe
I searched the forum for this discussion, I found a few threads but didnt really find the answer that I am looking for. Right now I have Doug Thorley 1 3/4" Tri Y headers, no cats, and im running true duals with flowmaster super 10s. I have read that with running true duals I am losing some HP and torque due to the lack of scavenging. Picking up some lost HP and torque sounds great, I also love the head turning eardrum bursting sound that I have now. I already have the magnaflow x pipe sitting in the box on my table, but here are my questions.
Will I really be gaining some HP and torque by adding the x pipe? Will I lose some of my sound by adding the x pipe?
#2 | |||
Original Bumblebee Owner
Drives: 265hp ZX-14, 500hp Silverado, V-ROD Join Date: Apr 2009
Yes, you will lose some sound and the sound will change from a classic V8 rumble to a modern V8 sound.
SYBIL
Its just that I love the way it sounds now, im really just adding the x pipe to gain the little bit of power back. Ive kinda been 2nd guessing having the x pipe installed because I dont want to compromise my sound if im not gonna be able to drive the car and tell that I gained a little power.
#4 | ||
Well before everyone running a x-pipe jumps in here and tells you to run one because they are, I'd say if you love the sound you have, keep it.
You have an h-pipe in there now? If not, an h-pipe helps similar to the x-pipe. Many will say x-pipe is better but then do you really need a couple more HP up at 5000 rpms plus? How much time does your engine spend at max rpm? Do you care more about every last hp or the sound you have?
#5 | |
SYBIL
#6 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
If you are running a true dual exhaust, meaning you've cut out the factory H pipe, you did lose some HP and Tq. Adding either a H or X pipe will bring back what you've lost. From what i've heard, the H pipe has more of a old school muscle sound where the X pipe has a little more modern muscle sound. There's not a BIG change in the sound, just a subtle one.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
#7 | |||
#8 |
SYBIL
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 SS Join Date: May 2013
An H-pipe or X-pipe is a must IMO, 3yrs we tested it on our free time on a dyno same day hours apart. This was on a 6.0L truck made 347rwhp 331rwtq with duals no cross over, 2hrs later with an H-pipe 351rwhp 337rwtq, 2hrs with an X-pipe made 354rwhp 340rwtq, 20min later 471rwhp 467rwhp with a lil nitrous lol.....
all runs done 2hrs apart on a 80* weather.
#10 |
SYBIL
X pipe is being installed as we speak
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Cyber Grey Camaro SS (LS3) Join Date: Mar 2010
I have an X pipe, and I will tell you that you are gonna waste time and money if you switch just to gain some power that you MAY not see on the dyno. Keep what you got.
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
I have an X pipe because mainly of sound and its slightly more efficient than the H.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
#13 |
![]() 2013 SS/RS 1LE VR-Backup System, SOLO Perforsance HF Cats, Muffler Delete, BBK Off-road X-pipe 2002 35th Aniversary SLP SS-Sold |
#14 |
OP,
So everyone who answered your question made comments about sound and power. No answer however gave a reason for the sound or power. An X pipe reduces back pressure, thus giving you more power and torque. By having an X pipe some of the exhaust from one bank of cylinders can pass through the exhaust from the other bank, thus balancing out the backpressure.. With many factory mufflers they are pretty restrictive at higher rpm's, thus an X pipe. You probably could measure the difference with a dyno, you wont notice it though. It helps with large displacement and forced induction motors because you are pushing a lot of air. On a stock motor just go for the sound.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears. |
