Old 01-01-2014, 10:10 PM   #1
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
Where can i buy 5mm wheel spacers
I need some 5 mm wheel spacers or something close for my pfadt coilovers . front spacer.
I have 20mm on now and there are to wide. thanks for the help.
Whipped416 is offline   Reply With Quote
Old 01-02-2014, 08:27 AM   #2
WhiteWizard13
Drives: 2014 2SS 1LE
This is what I just put on my new 1LE (front only). Jon at Best Wheel Deals gave me the heads up on these:
http://www.ebay.com/itm/5MM-BMW-SPAC...p2054897.l4275
Needed to put my Niche Apex wheels with Vredestrein tires on for winter storage and they would not clear the 1LE front struts. Works perfect and quick delivery.
WhiteWizard13 is offline   Reply With Quote
Old 01-02-2014, 11:31 AM   #3
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
How thick of a spacer can you add before you would need longer studs?
90503 is offline   Reply With Quote
Old 01-02-2014, 10:38 PM   #4
Whipped416
Whipped416's Avatar
thanks whitewizard...
any vibration with these?
Old 01-02-2014, 11:01 PM   #5
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Akata,
5mm,
from Ebay,
hubcentric,
no vibrations.
Just check the application. Ebay does not seem to keep my old transactions I cannot look it up. I can go into the garage and check the number on it if you like:
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 01-02-2014, 11:13 PM   #6
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS
Here's some.
http://mightym0use.wix.com/mm-soluti...-spacers/c14yp
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 01-02-2014, 11:32 PM   #7
90503
90503's Avatar
I googled Akata spacers and this came up....lol....
http://www.clublexus.com/forums/the-...m-spacers.html
From what little I've researched so far, I think I'd feel safer with the Eibachs....you don't lose any stud length, and they locate on the old hub and include a new hub so the wheel locates on it....(don't think they have 5mm, though)
Old 01-03-2014, 08:51 AM   #8
WhiteWizard13
Not sure about the vibration....My new 1LE is sitting inside at the dealership (for 2 weeks now) waiting for decent weather to drive home. My friends in service installed the spacers and swapped my wheels out for me. The spacers were a perfect fit and appear to be very good quality.
I'll probably run this setup in early spring when the mornings are still cold and then put the 1LE rims with GY F1's back on in the summer.
