Old 01-02-2014, 01:38 PM   #1
Anthony @ LG Motorsports
Drives: 1994 1LE / 2006 Z51 Corvette
*RELEASE* LG Motorsports Mono Ball Control Arm kit
LG Motorsports brings total suspension control to your Gen5 Camaro with their mono ball control arm package.
As found on our winning race cars, these spherical bearings come complete with all housings and spacers needed to replace the sloppy and weak rubber bushings found on your stock Camaro. Using spherical bearings in the control arms will maintain your alignment settings, remove any and all deflection from the control arm bushings giving you a positive feel on the road. Removing deflection will also reduce or eliminate wheel hop problems that can so badly plague the new Camaro's.
Bearings are a high quality, Teflon lined unit for long lasting quiet performance. Housings are either made from lightweight machined aluminum or high strength steel depending on location. Kit also includes lightweight aluminum rear adjustable toe rods.
Full package includes:
  • -Front control arms with bearings and spacers
  • -Front radius arms with bearings and spacers
  • -Rear lower control arms with bearings and spacers
  • -Rear upper control arm forward bushings
  • -Rear adjustable toe rod with hardware
  • -Rear trailing link with bearings and spacers
Kits can be had as a DYI kit and you install into your own arms, you can send your arms in for the install, or lastly you can purchase the entire kit installed into new GM arms ready to bolt into your Camaro.
Shown here on a Corvette you can see just how much the rubber bushings can move under even a light load like the dyno.
Anthony @ LG Motorsports is offline   Reply With Quote
Old 01-02-2014, 01:51 PM   #2
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
If you order the kit installed into new GM arms, would that come with a core charge where we can send back our existing arms?
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 01-02-2014, 02:15 PM   #3
Depends, on the Corvette kits we do offer an exchange program. If your arms come back in usable shape then we can do it on a core exchange. If you wanted brand new arms specific then there might be a slight cost involved. Luckily the stock arms are not that expensive on the Camaro's.
Old 01-02-2014, 05:32 PM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Can you PM me a price on a set of the FE4 an up LCAs doing 1LE bar swap on my 10SS
Old 01-03-2014, 11:12 AM   #5
PM's sent
Old 01-03-2014, 11:30 AM   #6
Splat
Splat's Avatar
Drives: 2012 1SS M6 IOM
Could you pm me a price on a full kit, 2012 SS.
Splat is offline   Reply With Quote
Old 01-04-2014, 09:45 PM   #7
jamesc1123
jamesc1123's Avatar
Drives: CGM 2SS RS w/ white stripes
PM prices on a full kit and the DIY Kit please.
LGM G6X3 cam, LGM headers, Vararam intake, throttle body and intake ported by ADM Performance, 477 hp 454 ft-lb tq, tuned by PCMforLess
jamesc1123 is offline   Reply With Quote
Old 01-05-2014, 04:48 PM   #8
gmdoctor
Drives: ZL1
Pm prices here as well. Full kit and diy
Thanks
gmdoctor is offline   Reply With Quote
Old 01-07-2014, 12:44 PM   #9
Pricing coming shortly!
Old 12-31-2017, 01:12 PM   #10
Cornercarver
Drives: 2011 2SS/RS M6
Did this ever happen? I don’t see them on your website?
Cornercarver is offline   Reply With Quote
