Old 01-02-2014, 03:59 PM   #1
Kiteboarder85
Kiteboarder85's Avatar
Drives: 2018 SS - 2015 SS 1LE - 2013 SS
Temperature for applying plasti dip
Has anyone worked with Plasti Dip in cold temps? I'm curious if its workable during the winter months out in the non-heated garage. I'll be doing the below the bottom grill area to meet up with the ZL1 style splitter. I miss my Camaro and I want to do SOMETHING over the winter.
Billy B.
Current: 2018 Hyper Blue SS
Kiteboarder85 is offline   Reply With Quote
Old 01-02-2014, 04:02 PM   #2
a.morblu
a.morblu's Avatar
Drives: 2011 Sinister SS
I just dipped my truck wheels. I did it outside and it was around 28*. No issues. Just had to wait a little longer between coats. You shouldn't have any issues, just make sure your first coat is thin.
a.morblu is offline   Reply With Quote
Old 01-02-2014, 08:26 PM   #3
Trunz150
Drives: 2014 2SS/RS Drop Top
Ditto on above post just did it in 30 degree weather no issues at all
Trunz150 is offline   Reply With Quote
Old 01-02-2014, 08:30 PM   #4
Kiteboarder85
Well...it's -17 today lol! Hopefully end of January it gets a littttttle warmer!
Billy B.
Old 01-02-2014, 08:31 PM   #5
ssfox
ssfox's Avatar
Drives: 2011 2SS/RS Vert
Don't try to do something that you want to peel off the excess though!
Example if you want to spray your emblems and peel off the overspray around them it will not come off clean. Only breaks away cleanly if the plasti dip is warm.
Take my word on that from the great white north.
2011 2SS/RS VERT
Moroso Catch Can,K&N CAI,Apex Air Scoop & Washer Relocate,ZL1 Grille,GTO Clutch Rez, Frameless 2013 mirror.
Tuned by MGS Performance
ssfox is offline   Reply With Quote
Old 01-02-2014, 08:56 PM   #6
yellowrs
Drives: 2010 SS 426 V8 M/T
I did my truck when it was 120 F in Phoenix AZ.
Needless to say that the plastic dip immediately started to orange peel.
I called the manufacturer and they told me anything under 70 F plus low humidity.
yellowrs is offline   Reply With Quote
Old 01-02-2014, 11:19 PM   #7
Vai
Drives: In the process of buying a Cam
I had a problem doing mine in the cold but it was because the can was left in the car trunk overnight in about 20F. It came out very thick but I just warmed up the can with a blow dryer and then the next day I redid the lights and warmed up the can with just warm water.
You should try to use a blow dryer to speed up the drying process. It works really well.
Good luck!
Vai is offline   Reply With Quote
Old 01-03-2014, 12:33 AM   #8
sappy
sappy's Avatar
Drives: white 2011 1lt
exactly.. just sprayed my lower grill in about 30 degree's. when outside working make sure your can is warm. what i did was turn the car on and the foot heat on high. between coats i would set the can on my floor and it would warm back up... otherwise it gets chunky out of the can. good luck
sappy is offline   Reply With Quote
