Drives: 2012 Camaro RS Join Date: Sep 2012
All-In-One Halo/DRL/Sidemarker harness for ZL1 Conversions ?
We recently created a custom version of our All-In-One Harness (http://www.camaro5.com/forums/showthread.php?t=259419) for an RS Camaro that did the ZL1 Front End Conversion.
This new version of the All-In-One Harness plugged into the OEM ZL1 front end harness on the one side, and the standard RS 8-pin DELPHI connector on the chassis side, plus it connected to the power lug at the fusebox to provide the additional power feed required for the fog lights in the ZL1 front end. It was designed to turn on the Fogs automatically whenever the headlights/sidemarkers are on. Alternatively, a wire could be brought out to enable an external switch to provide ON/OFF control for the Fogs. The price would be a bit higher than our standard All-In-One Harness, but it is a very clean solution because all of the extra parts fit inside the All-In-One controller module. The only visible difference between this harness and our standard All-In-One harness is the extra power wire. Please PM us if you'd be interested in this type of harness. Thanks, --Keith |
