Old 01-05-2014, 02:11 PM   #1
sac130e
Drives: 2014 Camaro SS/RS BRM
Removing Dealer Decal
Need to remove the dealer decal on the trunk lid, looks like a vinyl sticker.
Have used GooGone before to remove glue from emblems, but checking if this is good to remove this, or something else might be better.
Also, guessing the badges on the trunk lid are stuck on and can be remove with the fishing line way?
Thx
sac130e is offline   Reply With Quote
Old 01-05-2014, 02:42 PM   #2
FLYNNZL1
Drives: Man
Send a message via ICQ to FLYNNZL1 Send a message via AIM to FLYNNZL1 Send a message via MSN to FLYNNZL1 Send a message via Yahoo to FLYNNZL1 Send a message via Skype™ to FLYNNZL1
If it is a vinyl sticker you should be able to peel it off. Dental Floss works as well as fishing line too. You can heat up the vinyl with a hair dryer to make it easier, just don't let it get too hot.
FLYNNZL1 is offline   Reply With Quote
Old 01-05-2014, 02:45 PM   #3
sac130e
It would seem to be vinyl, but not like the stripes that come with the car.
It has a rough texture to it and almost seems painted on, but can't imagine any dealer would actually paint there logo on the car.
Old 01-05-2014, 02:49 PM   #4
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
If I buy a car that has one on it I usually do one of two things. Ask the dealer to remove it before delivery or peel it off as soon as I get home. They usually come off pretty clean if they haven't been on very long.
The Bird is the word!
Old 01-05-2014, 02:52 PM   #5
CMRO.SS
CMRO.SS's Avatar
Drives: 2016 C7
Don't use rubbing alcohol. I made that mistake and took some paint off the car.
2012 Camaro SS 712 rwhp sold. 2015 ZL1 sold.
CMRO.SS is offline   Reply With Quote
Old 01-05-2014, 03:11 PM   #6
Angrybird 12
Never had a problem with rubbing alcohol, in fact installation instructions to install emblems using 3m tape tell you to use it to remove wax and grease to clean the surface.
Old 01-05-2014, 03:36 PM   #7
CMRO.SS
CMRO.SS's Avatar
Drives: 2016 C7
Right. That's what I thought too. I've done it 100 times on my other cars with no problem. Oh well I put a JRE emblem over it.
Old 01-05-2014, 03:38 PM   #8
Angrybird 12
One thing you have to make sure it's the 70% and not pure alcohol.
I have used it on this Camaro and in my 2010 before it with no issues.
Old 01-05-2014, 03:43 PM   #9
CMRO.SS
CMRO.SS's Avatar
Drives: 2016 C7
I was using pure alcohol. Thanks for the info
Old 01-05-2014, 05:45 PM   #10
AmericanMuscleCars
Teenage Dream Camaro
AmericanMuscleCars's Avatar
Drives: A Visually Stunning Camaro
peel off, then all you need to do is use turtle wax bug and tar remover, let it dwell, rinse off. If it won't rinse off use a two bucket wash with grit guard on that spot and rub with mitt. Always re-apply sealant or wax after doing so, it says it won't strip wax, better to add a layer just in case because it does use harsh chemicals.
AmericanMuscleCars is offline   Reply With Quote
