Old 01-05-2014, 06:30 PM   #1
AG1LE
AG1LE's Avatar
Drives: '14 1LE
Question Eaton Truetrac Issues
Has anyone broken an Eaton Truetrac posi in a Camaro? Under what conditions?
Did you find it makes more noise than the stock posi?
Experienced any issues with performance on a road course?
ANY disadvantages versus the stock posi (other than the fact that it cannot be rebuilt)?
Mine will be delivered tomorrow and I want to make sure I'm not making an expensive mistake - this is a daily driver that I plan to track, and the posi will be installed with a GM 3.91 gear, JRE billet caps, and upgraded diff/subframe bushings.
Thanks!
AG1LE is offline   Reply With Quote
Old 01-05-2014, 07:32 PM   #2
Merc
In The Circle
Merc's Avatar
Racing it?
Old 01-05-2014, 07:35 PM   #3
AG1LE
AG1LE's Avatar
Drives: '14 1LE
I plan to track it - I've seen a lot about how well it performs in a straight line, but want it to perform equally well through high speed turns on a road course (and low speed turns on the street).
Old 01-05-2014, 10:28 PM   #4
ZOOK
ZOOK's Avatar
Drives: 2010 2ss 6 speed
tru-trac
12,000 miles on mine
Works great and drive it every day to work 600+ hp
ZOOK is offline   Reply With Quote
Old 01-05-2014, 10:47 PM   #5
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Thanks!
I have literally the exact same setup as you listed with a GFORCE1320 driveshaft. Took this week off work to put it in. Hope its worth it!! Lol. This turned out to be an expensive setup.
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 01-05-2014, 11:37 PM   #6
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
I'm at 800+ and mine holds up well under any conditions that I've thrown at it.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 01-05-2014, 11:45 PM   #7
Juice2SS
Drives: 2011 2SS
I'm getting one myself. I am going for straight line though. I'm not much of a road course guy. I hope it works out for ya.
Juice2SS is offline   Reply With Quote
Old 01-06-2014, 09:11 AM   #8
bhillakaiceberg
bhillakaiceberg's Avatar
Drives: 2011 2SS/RS & 2017 1SS
I got my Truetrac last week. I will be installing it shortly. Plan to only go straight lines also tho.
2011 Chevrolet Camaro 2SS/RS L99 (1 of 782)
10.78 @125mph ALL MOTOR SBE
Built/Tuned by Me
2017 Chevrolet Camaro 1SS Auto
9.29 @144.57mph ALL MOTOR SBE
#TEAMGPI Gwatney Performance Innovation
bhillakaiceberg is offline   Reply With Quote
Old 01-06-2014, 10:01 AM   #9
Merc
In The Circle
Merc's Avatar
M6 is as hard as is gets on drive train. I killed two diff's one stock one and one modified. The stock posi is the weak link in both cases it broke the spiders. I now have a DSS 12 bolt. The next weak link is the two piece drive shaft and then axels. I have DSS aluminum drive shaft and DSS axels and have no regrets.
Old 01-06-2014, 11:40 AM   #10
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
PM sent.....
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
Old 01-06-2014, 12:03 PM   #11
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
just curious, whats the cost to change to a Eaton with gears on the stock set (doing it right)
Driveshaftshop is offline   Reply With Quote
Old 01-06-2014, 12:10 PM   #12
Merc
In The Circle
Merc's Avatar
Around $900 for the parts, providing you can get the GM 391's which are currently on back order.
Old 01-06-2014, 12:39 PM   #13
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
I'll summarize....these prices may be inflated just a tad to account for shipping and/or price variations....
Eaton True-Trac: $600
GM 3.91 Gears: $300
Full Install Kit: $200
JRE Billet Caps: $180
Total: $1280 (parts costs)
blazzin1 is offline   Reply With Quote
Old 01-06-2014, 12:45 PM   #14
Driveshaftshop
wow, dident realize it would be that mush. so what about 1500.00 installed then ?
