NM HT5
Lowest lowering springs?
im pretty sure I seen someone mention springs that lower the car 2.3" or 2" I don't know the brand though... I know it wasn't the H&R supersport springs.. Also is it possible to mix and match springs? i have the eibach pro kit, but hate how much gap i have in the rear of the car, the front is fine
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
I don't know of a set of just springs that will lower your car more than 1.75in. If you care about the ride at all, you'll go with a set of coilovers instead.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
![]() Drives: 2011 CAMARO SIM 2SS/RS Join Date: Nov 2012
#4 | |
Drives: 2010 SS Join Date: Jan 2014
I think 2inches is way to much, I got bmr 1.5 all around and I have to be careful with speed bumps
#6 |
![]() Drives: 2010 2SS/RS M6 Join Date: Dec 2013
I have 2 inch drop springs I ordered them online a ways back I wanna say From BMR. you will sacrifice ride quality for sure, it's a lot more stiff... but they aren't as bad as everyone thinks. Haven't had any problems with suspension(yet) and the car looks amazing. I would go at least 1.5. A 1 inch drop isn't much to look at IMO. I can post a pic if you want to see
#7 |
BMR only make 1 inch and 1.4 inch lowering springs for the SS.
#8 |
Yeah I got the 1.4
#9 |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Race Car Join Date: Sep 2009
This is 100% correct. We don't recommend going any lower than 1.4" with lowering springs which is why our lowest spring option is 1.4". If you go lower than 1.4" with lowering springs you will have a very marginable ride at best and you will have an issue getting decent alignment specs out of the factory hardware. If you want to go lower than 1.4" we really recommend going with coil-overs.
#11 |
Can't find the box I had them in. I just moved to Hawaii so I may have tossed it.. They are red and look like BMR's may be I just got the brand mixed up.
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
If you go too low you will max out the upper control arm front bushing and cause it to fail.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
#13 |
