Old 01-07-2014, 10:29 AM   #1
usmc-ashton
Drives: 2010 camaro v6 black, bbk intake
curiosity about RPMs
sometimes when i stop at a red light, the rpms would move up and down a litte bit, nothing major the needle just moves to where you can notice it. is that normal i dont think ive seen that before. thaks
usmc-ashton is offline   Reply With Quote
Old 01-07-2014, 10:30 AM   #2
40years
40years's Avatar
Drives: 2016 CAMARO 1SS Hyper Blue Met.
normal
proud member "club elite" # 89
40years is offline   Reply With Quote
Old 01-07-2014, 10:55 AM   #3
davidmk001
davidmk001's Avatar
Drives: 2010 Chevy Camaro 1SS
I have the same ‘problem’ (if you even want to call it that). At idle I would get an RPM needle bounce. See thread below. One suggestion was to disconnect the battery and then reconnect. Don’t know that will actually do anything, but since the car’s parked right now, I took the battery inside so it won’t die on me in this extreme cold we’re getting here in Canada. Looks like I will know come spring.
Does your car have an aftermarket intake?
http://www.camaro5.com/forums/showthread.php?t=291599
davidmk001 is offline   Reply With Quote
Old 01-07-2014, 10:58 AM   #4
usmc-ashton
yes, it has a bbk cai
Old 01-07-2014, 11:07 AM   #5
davidmk001
davidmk001's Avatar
I did notice that once I had put my K&N on if you blow into it the idle will change and drop. Almost like the engine is about to stall out. You can tell the engine rhythm changes. Did it start to happen after the intake was put on?
