![]() Drives: 2011 Silver Camaro SS Join Date: Feb 2012
Skip Shift Problem
I recently brought my car to a shop to have new tires put on + adjust the height of the coils. The mechanic went ahead and resetted my check engine light.
For the past 2 weeks when the skip shift screen pops up (1-4), i'm locked out of 2nd, 3rd, and 5th gear......FOREVER! I've had my car since 2011 and whenever the skip shift screen comes on, I get locked out for a couple seconds and then it lets me back in. The first time this happened I pulled over, turned off the car and turned it back on and it let me back into all gears. However, this happened again yesterday and I was locked out for about 15 minutes. The skip shift screen popped up again while I was locked out and when it went away, it unlocked the gears... I've gone ahead and ordered a skip shift eliminator, but i'm not sure if it's going to work. http://www.amazon.com/SLP-Performanc.../dp/B002WBRRHE Anyone have any idea why this happening? Any help is appreciated! |
That should prevent the lock out from being able to physically activate but there seems to be a deeper problem. CAGS is definitely not functioning properly.
Do you think it's possible that when the mechanic got rid of the CEL, something might've affected the CAGS?
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
What was the code for the check engine light before it was cleared? Before my tune, it would lock out 2&3 for a few seconds, but not 5th and not forever. If your not out of warranty and not heavily modded, take it to the dealership.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
#5 | |
Only mods I have are: 1. K&N Intake 2. Ark N-II Exhaust System 3. JBA Mid-Pipe 4. BC Racing Coilovers I have 7 year warranty so i'm good but a friend of mine told me the dealership could void my warranty for the mid-pipe and coilovers
#6 |
GrINned & JUICEd
If they void you for those mods, they would just be total a$$es. Unless when the shop that installed the exhaust damaged some wiring or the exhaust is in contact with the wiring and melted the insulation. Doubtful though. The CAGS wiring is up high on the trans, iirc, but never know.
#7 | ||
Will This Modification Void My Warranty? |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '14 1LE Join Date: Nov 2013
In theory I believe this is true, but in practice it may not be as easy as it sounds. A good dealership will be reasonable and work with you, but a not-so-good dealership may just throw their hands up and blame the problem on your mods because that's the easiest solution for them. Be prepared to push them a bit (respectfully) if they start claiming a direct connection to your mods that doesn't make sense, or that they can't fully explain. At the end of the day they can do whatever they want (reasonable or not), but given the issue you're having, I think it's worth a shot.
#9 | |
#10 | |
#11 |
![]() Drives: 2013 AGM 2SS/RS 1LE Join Date: Apr 2013
this same scenario just happened to me today. I became completely locked out of 2nd and third gears for a couple of miles. guess it is going back to the dealership. car is completely stock. Did a CAGS eliminator fix the OP's problem?
#12 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: GM Vehicles Join Date: Jun 2010
Sincere apologies to hear about the transmission concerns. Though you're seeking opinions, I'd be happy to communicate this with the designated Customer Experience Manager (CEM) at your preferred dealer if you feel an official diagnosis is necessary. Feel free to message us privately if you'd like to proceed, or discuss this situation further. William R. Chevrolet Customer Care |
#13 |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
The skip-shift eliminator will only allow you to go in second. So you'll have access to 1st, 2nd, and 4th. AFAIK, you'll still be locked out of 3rd as the connection is only severed to the second gear lockout solenoid.
EDIT: I'll check when I get home! Great excuse to go out for a drive!
#14 | |
![]() ![]() ![]() ![]() Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
