Old 01-07-2014, 08:48 PM   #1
ToddB
Drives: 2011 2SS Convertible Supercharged
Cam install with a whipple
Have any of you with a whipple supercharger able to install a cam without removing the front of the car and the intercooler. Is there enough room to install a cam without removing the intercooler. Thanks for any input.
ToddB is offline   Reply With Quote
Old 01-07-2014, 09:59 PM   #2
Drottie
Drottie's Avatar
Drives: 2011 Camaro SS Convertible in VR
My guess, from what I remember is no, the radiator and a/c condenser has to be removed, I'm betting the intercooler would also be in the way. Also, sorry Not to high jack the tread but what exactly does the ADM FPCM do for you, and do you Have to use it when switching to ZL1 or CTSv dual pump set ups?
SICC, Southern Illinois Camaro Club On Facebook
2011 SS/RS LS3/M6 convertible
Victory Red, Black top w/Nightshades 1LE graphics
Whipple 2.9L with 3.875" pulley
CBI ESAD cam with Tooley springs
ADM fuel with ID850 injectors DSX Tune
MGW shifter
20" TSW Nurbering 275/315 Nitto NT05
Carlyle Performance 15" kit with Pfadt solid subframe inserts
C.A.I. cold air intake
SLP LT headers, 3" exhaust, no cats, x-pipe
ZL1 dual mode mufflers
Lighting controlled by NightOwl
2010 SS/RS LS3 - SOLD-
#15,852 build date 06/05/2009
CGM w/flat black stripes
Drottie is offline   Reply With Quote
Old 01-07-2014, 10:41 PM   #3
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS
Ya, you need it all out of the way. Got to pull the front clip. AC condenser just pulls out of the way and you tie it up. Sorry, no short cuts.
Look up the DIY by Robert Way (I think that's his name) and it will be easy.
Don't forget the cam installation kit, degree wheel, soft valve spring, adjustable push rod and all that other stuff. If you have quit a few miles change the timing chain and since you will have the oil pump off for that replace it as well. Now go do it.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 01-08-2014, 12:21 AM   #4
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
I didn't pull the front clip when I did mine. The heat exchanger for the Whipple does not get in the way.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 01-08-2014, 06:49 AM   #5
ToddB
Thanks that is what I wanted to know.
Old 01-08-2014, 06:51 AM   #6
ToddB
The FPCM is needed for the ZL1 fuel pump. The stock FPCM wont let it reach maximum output.
Old 01-08-2014, 06:53 AM   #7
ToddB
only have 9000 miles on car. Springs and chain are staying in the car. Looking for longevity from my cam install and went with a small LS9 cam.
