Old 07-22-2009, 05:50 AM   #1
mark_p
Drives: 2010 2SSRS m6
ls3 cam experts needed.. opinion..
My shop has speced out a Comp Cam .224I/.228E with 581/592 lift and at 114. I told them I was looking for excellent street manners with a small amount of lope and good power and torque throught most of the range (1700-6800). I know LS3's have performed a little different than previous years ls engines and need advice from those that know..... I need advice soon as the cam will be ground tomorrow..
mark_p is offline   Reply With Quote
Old 07-22-2009, 06:23 AM   #2
FTI-EDC
The stick man
FTI-EDC's Avatar
Drives: 2004 GTO - C5 'vert - SRX
It'll work... nothing like I would have used on an LS3 but you will see an improvement in power over stock and it will idle pretty smooth...
PONY WARS
FTI-EDC is offline   Reply With Quote
Old 07-22-2009, 06:31 AM   #3
ADM PERFORMANCE
Drives: Anything I want
Go to my website(WWW.ADMPERFORMANCE.COM) and click on ONLINE STORE ,CAMARO , STAGE 2 CAM PICTURE....
ADM PERFORMANCE is offline   Reply With Quote
Old 07-22-2009, 07:15 AM   #4
mark_p
can someone give me some profiles then. I know everyone wants to sell there own cam but I need a little help here. This is a forum you know....
Old 07-22-2009, 08:14 AM   #5
Robin Lawrence
Robin Lawrence's Avatar
Drives: 2010 Camaro 69 Nova
Man you really don't want to ask that. Everyone is going to tell you they cam they have is the best thing since sliced bread.
There are so many different aspects involved it make things interesting.
It's like dinner,many different tastes out there. You need to do some research and then make a choice.
I did a LS3 cam test for GM High Tech Magazine. We ran the stock cam plus 10 others on the engine dyno. The story should be out in a month or two. It shows a wide range of cams designed for the street.
I think that your Comp Cam was the one we tested from Comp.
FTI-EDC knows his stuff, I wish I could have tested his cam also. Mostly advertisers cams.
Robin
Holley Performance Products
Robin Lawrence is offline   Reply With Quote
Old 07-22-2009, 11:53 AM   #6
mark_p
new cam speced. Me and the tuner had a misunderstanding of what I wanted. he is now speccing a more split cam..
216/229 561/562 113lobe
He says this will work best on the l92 heads since the intake flows so much better than the exhaust with stock porting. He is also suggestion Com Cams 921 double springs and hardened pushrods......
Old 07-22-2009, 11:58 AM   #7
Jason 98 TA
Drives: Camaro
We're getting a LS3 together to go on our engine dyno in the next week or so. From there we'll be developing some camshafts for many different applications. I'll let you guys know what we find!
Jason 98 TA is offline   Reply With Quote
Old 07-22-2009, 12:28 PM   #8
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
FYI .. that is a pretty tame cam .. if your looking for some power gains and retain driveablity that should do it ..
Crowley
Crowley is offline   Reply With Quote
Old 07-22-2009, 12:37 PM   #9
pharmd
Master of Medicine
pharmd's Avatar
Drives: 4th Gen
Robin
^2...and he's on here at least trying to help...where are the others?
2002 Camaro SS. 408 LS2. 500+RWHP/480RWTQ. Full UMI RR suspension. Koni/Strano. 295F/315R. 3500#(55/45)
pharmd is offline   Reply With Quote
Old 07-22-2009, 01:29 PM   #10
Mike TexaSS
Drives: 454 LS7 Camaro SS
The LS3 likes alot more split between the intake and exhaust.
I have 2 LS3 cams in stock
227/243 .613 .623 115 LSA
And the big dog cam
239/251 .623 .623 115 LSA
Mike TexaSS is offline   Reply With Quote
Old 07-22-2009, 01:35 PM   #11
21STCENTURY
Drives: Z28/700HP, CTSV/850HP, Viper/725HP
LS3 Camshafts
We have a new line of LS3 camshafts that just arrived a couple weeks ago
These were specifically designed by Comp Cams for the LS3 engine.
These are in stock and priced at $399.00
Best Regards,
John Page
Twenty First Century Muscle Cars
21STCENTURY is offline   Reply With Quote
Old 07-23-2009, 11:30 AM   #12
FTI-EDC
The stick man
FTI-EDC's Avatar
Robin
Thanks Uncle Robin...
Sure would have upset the apple cart had you throw one of my sticks in that test.
BTW.... we need to talk soon. I have some interesting info on a new LSR cylinder head program you might want to take a look at.
Ed
PONY WARS
Old 07-23-2009, 11:45 AM   #13
Robin Lawrence
Just to throw some more fuel on the fire.
Installing a cam in a 2010 Camaro isn't going to net the same results as some other cars. Unless you concentrate on the mid range torque this car is going to feel slower at low to mid range RPM's
In the past we have been able to install steeper gear ratios to get the engine into a different power band. That is not the case on the 2010 Camaro. We don't have an option of gearing.
Now if you want big numnbers from the chassis dyno then you should be good to go.
WIth a car that weighs close to 4100 pounds with driver you need to concentrate on making more torque in the low and mid range. That is what will make this car feel like it has a bunch of power.
Take a look at torque when choosing your cams.
Robin
Old 07-23-2009, 11:55 AM   #14
PolishMike
PolishMike's Avatar
Drives: 2010 2SS RS
Noob question here - is there enough room to swap cams without pullin the engine? Looks like there is. Heads have to be pulled on an ls3 right?
PolishMike is offline   Reply With Quote
L99 and LS3 Cars needed in Central Ohio Re Raise Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 06-19-2009 07:24 PM
opinion needed masterjg24 Camaro Price | Ordering | Tracking | Dealers Discussions 3 05-13-2009 10:40 PM
stripes opinion needed 2010 camaro inferno 5th Gen Camaro SS LS LT General Discussions 3 05-08-2009 10:30 AM
Opinion on Interior Needed? ArcAngel 5th Gen Camaro SS LS LT General Discussions 17 01-03-2009 11:20 AM
installing hot cam logan1080 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 47 11-23-2008 06:12 PM
