Old 01-09-2014, 10:03 PM   #1
CMRO.SS
CMRO.SS's Avatar
Drives: 2016 C7
more hp
I see a lot of people with the same mods I have making 30- 40 hp more than me. What do you guys think. I have Dynotech headers, JRE Scoop, JRE Rough Iddle cam, 3.91 gears, mgw shifter, Borla Attack exhust, JRE 470 Package, CAI Intake, Dyno tunned by jannetty racing
2012 Camaro SS 712 rwhp sold. 2015 ZL1 sold.
CMRO.SS is offline   Reply With Quote
Old 01-09-2014, 10:54 PM   #2
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
Who did the cam install? Was it degree'd correctly? If its a tooth off (retarded) it will probably still run with reduced power.
Ive seen LS3 cars make 430-440rwhp with just full bolt-ons and dyno tune, without a CAM.
However, no 2 dynos are the same. Dynojet numbers will read higher then mustang dyno numbers. Humidity, weather, elevation, it all plays a factor.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
Old 01-09-2014, 10:57 PM   #3
11TexaSS
11TexaSS's Avatar
Drives: 2011RedJewel, FI
Well different dynos are going to give different numbers. Dyno jet dynos are known to be a bit more generous then mustang dynos. Weather conditions can also factor in to results. Don't get hung up on comparing to others. Use the dyno as a tuning tool to see benefits of your mods.
11TexaSS is offline   Reply With Quote
Old 01-09-2014, 11:03 PM   #4
CMRO.SS
CMRO.SS's Avatar
Drives: 2016 C7
All work was done by Jannetty racing. He did day that my gas sucked if that makes a big difference
Old 01-10-2014, 12:00 AM   #5
62nalide
62nalide's Avatar
Drives: 2013 SS
Edit:
I rather not
62nalide is offline   Reply With Quote
Old 01-10-2014, 12:18 AM   #6
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Originally Posted by 62nalide View Post
Edit:
I rather not
Lmao
^^^im with stupid.
Old 01-10-2014, 08:58 AM   #7
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
If you had bad gas then yes you could still have more timing left in your tune which is hp left on the table. Try using Rhino or Matt at FSP and they can squeeze all that HP out!!
Camarojt is offline   Reply With Quote
Old 01-10-2014, 10:35 AM   #8
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
the power is very close for a 223 cam. as mentioned above if you had some bad gas it could be a few more ponies.
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.12@156
2010 Camaro
Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146
94guy is offline   Reply With Quote
Old 01-10-2014, 03:10 PM   #9
CMRO.SS
CMRO.SS's Avatar
Drives: 2016 C7
So you guys think my cam is on the small side
Old 01-10-2014, 07:02 PM   #10
HardrockSS
Drive Fast Take Chances
HardrockSS's Avatar
Drives: 2012 45th anniversary SS
Go see Don at Slowhawk! Isn't it called JRE 470 package for a reason?
2012 45th Ls3 M6:ECS 1500, Custom Cam ,Alky Meth kit, Mcleod Rxt, MGW shifter,Pfadt Tri-y headers Solo Mach X, 20%tint,3.91 gears ,Suspension upgrades, G-force axles.700 RWHP
http://www.slowhawkperformance.com/
HardrockSS is offline   Reply With Quote
Old 01-10-2014, 07:19 PM   #11
LS3 SS
Drives: 2010 Cyber Grey Camaro SS (LS3)
LS3 SS is offline   Reply With Quote
