Old 01-10-2014, 06:34 PM   #1
Bhobbs
Bhobbs's Avatar
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle
Replaced rack n pinion, now steering wheel has side to side play
I replaced the rack and pinion on my 98 Z28 because it was leaking fluid and after getting it aligned, the steering wheel has some side to side play in it. I can turn the wheel a few degrees to each side without the wheels of the car turning. Is there an adjustment I need to make or should it go back to the shop where I had it aligned?
Bhobbs is offline   Reply With Quote
Old 04-07-2014, 12:33 PM   #2
Bhobbs
Bhobbs's Avatar
Bumping this back up. Still having issues with the steering.
Old 04-07-2014, 02:39 PM   #3
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
Make sure the steering shaft bolt is tight.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 04-07-2014, 03:12 PM   #4
Edwin320
Drives: 2018 Camaro ZL1 Convertible A10
Check the condition of the rag joint:
http://www.jegs.com/i/Dorman/326/310...FYN0OgodxDEA8A
(that isn't the one for your car, but you have something similar)
and check the condition of the tie rod ends. Racks usually come with inner tie rods but the outers are usually re-used. If all that checks out, make sure your steering column isn't the source of the play.
Ed 2018 ZL1 A10 'Vert
Edwin320 is offline   Reply With Quote
Old 04-11-2014, 03:54 PM   #5
Bhobbs
Bhobbs's Avatar
Thanks. I'll check both this weekend. Didn't have a chance to jack it up and take a look yet. Hopefully I don't have to change out the rack and pinion.
It's been a while since I changed it but I think the replacement came with new outer tie rods.
