![]() Drives: 2012 camaro 2LS Join Date: Sep 2013
Slipping clutch? Help! Lol
Hey everyone. so I'm back with yet another issue with my car. So I have a spec stage two clutch and aluminum flywheel in my car and lately when the car is cold the clutch engages super late and slips just a bit under moderate to heavy acceleration, at least that's how it feels. Now here is the strange part, once the car heats up it grabs much earlier in the pedal range and won't slip even under full boost and a little nitrous? The shop I have it at seems stumped, but wants to take the trans off and look at it, but I'm am worth of afraid they are just hunting around not really knowing what they are looking for? Their a great shop but I don't want to waste the money if I don't have to. Any ideas anyone?
PHAT B33
Drives: 2012 TF3 Camaro 2SS/RS M6 Join Date: Jun 2012
Sounds like there is still a bit of air in the slave cylinder at the clutch. Bleed, bleed, bleed. When I had the issue on a turbo LNF Cobalt SS it was air in the line and got worse with cold temps after putting in a SPEC Stage 2+ and a LW flywheel. Getting ALL the air out fixed it.
Thanks! I had offered that explanation to the shop and the dismissed it as highly unlikely, I'll now demand that they bleed it. Or even try it myself. Any idea where the correct bleeder screws are and what I have to do to get to them?
PHAT B33
Not on yours, sorry. On the LNF setup it was on the top of the clutch housing where the hyd line enters it.
Have a helper apply pressure to the clutch pedal but not enough to engage it, loosen the bleeder as they push the pedal down & tighten the bleeder before they release it. Repeat as necessary. A line from the bleeder to a glass jar helps keep from making a mess and if you keep some fluid in the jar there is a less chance of getting air back in. Since the bleeder isn't at the slave cyl it takes time for all the air to migrate up out of the slave near the bleeder or above to get it out of the line. You can put a vacuum bleeder on the clutch master cyl to help draw the air out but I never had much luck getting it all out that way. Hope you get it, 99% sure that's it.
#5 | |
![]() Drives: 2010 Camaro SS manual all stock Join Date: Jun 2012
i had an eagle talon, but that thing was just one big design flaw after another.
#6 |
PHAT B33
I had it for 3 years and modded the hell out of it. Learned to tune on it with HPTuners and it was direct injection so many of the same things apply. I used to help a lot on CSS.net and HPTuners 4 cyl forums also. Went on from there to work on the '02 WS6 until I got the Camaro.
| Tags |
| clutch, slipping clutch, spec clutch, transmission |
