Old 01-11-2014, 11:08 PM   #1
Android42019
The Black Emerald
Android42019's Avatar
Drives: '17 ZL1, '08 Trailblazer, '11 1LTRS
New tires(Rear)....?
Hey guys im in need of some new tires and was wondering what y'all recommend and has anyone used this Pirelli instead of the $500/each tires?
http://www.discounttire.com/dtcs/fin...394&vid=020778
Android42019 is offline   Reply With Quote
Old 01-11-2014, 11:39 PM   #2
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
$500 each? Maybe you're thinking run flats? Stock Pirellis are not run flats. I think you can get stockers for as low as $225 a tire...maybe less
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 01-11-2014, 11:42 PM   #3
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
I'm running BFG G Force Sport Comp 2's. I love em
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 01-12-2014, 12:17 AM   #4
Android42019
The Black Emerald
Mmm....$489/each....those G force look tasty....
http://www.discounttire.com/dtcs/fin...639&vid=020778
Old 01-12-2014, 12:38 AM   #5
10splaya22
10splaya22's Avatar
Drives: 2012 Tacoma
Those same Pirellis are only 259 each: http://www.discounttiredirect.com/di...0&rd=20&cs=275
10splaya22 is offline   Reply With Quote
Old 01-12-2014, 01:15 AM   #6
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Better tire IMO: http://www.discounttiredirect.com/di...0&rd=20&cs=275
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 01-12-2014, 02:03 AM   #7
Android42019
The Black Emerald
If you went to both links you would see they are different tires. One says CHV one says BEN, that's where I'm confused.
Old 01-12-2014, 02:05 AM   #8
Android42019
The Black Emerald
Originally Posted by Dizzy82 View Post
You do notice it's an SUV tire and not the same speed rating...?
Old 01-12-2014, 02:09 AM   #9
rebelyell22
Go with the G Force Sport Comp 2. Cheaper than the Pirelli's, longer tread life, higher speed rating, and better traction. You won't be disappointed
Old 01-12-2014, 02:15 AM   #10
Android42019
The Black Emerald
More than likely what ima go with man, thanks for the input guys. *thumbs up*
Old 01-12-2014, 09:03 AM   #11
2011*Camaro*SS
2011*Camaro*SS's Avatar
Drives: 2011 Camaro 2SS/RS Vert
What about the new Nittos? I think they are called the Motivo. Are they any good? They have a 9.1 customer rating on Discount Tire.
2011*Camaro*SS is offline   Reply With Quote
Old 01-12-2014, 09:05 AM   #12
2011*Camaro*SS
I'm also looking for new tires and I've heard these are pretty good. They are just a little cheaper than the pirellis.
Old 01-12-2014, 09:12 AM   #13
RollaMo
RollaMo's Avatar
Drives: 2017 2SS
The factory tire is not a $500 each tire. Not sure why they are listed for that much at Discount Tire.
Here is a link to Tire Rack showing the Pirelli P Zero OE tires for a 2011 SS.
http://www.tirerack.com/tires/tires....utoModClar=2SS
$866 for a set of 4
With that said, I think there are better all around tires out there.
Especially if you live in a colder climate. The Pirelli's suck in cold weather.
I just put a set of General G-Max on our car, and really happy with them.
They are much better in the cold.
1996 Corvette - LT4
2017 Camaro 2SS
2019 GMC Sierra 2500 HD
2015 Harley Davidson Ultra Limited
RollaMo is offline   Reply With Quote
Old 01-12-2014, 09:33 AM   #14
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
$866 for a set of 4
OP, here you go...same tires "ZR" @ $236
