Old 01-14-2014, 11:29 PM   #1
parkfam
Drives: 2013 Camaro 2 SS
AFM disabling
GM is recalling silverados for overheating. Seems the on board computer is not shutting down the cylinders as designed thus causing the overheating and potential fire possibilities. Just curious if purchasing and installing a RANGE AFM disabling device, might possibly cause the same result. Has anyone currently running a RANGE, experience similar overheating?
parkfam is offline   Reply With Quote
Old 01-14-2014, 11:31 PM   #2
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
your not going to get overheating from turning the system off. It will just run on all 8 like it should.
JCunningham is offline   Reply With Quote
Old 01-14-2014, 11:35 PM   #3
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
Been running almost exclusively with the Range active for around 7,000 miles now with no trouble whatsoever.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 01-15-2014, 07:20 AM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
The effected Silverados (4.3l V6 and 5.3l V8, 6.2l V8 not included) have engine software errors that could cause exhaust components to overheat when idling leading to fire. There is no reason to connect it to the Camaro or the Range AFM delete module.
afm removal, range technolgy
