Old 01-17-2014, 06:21 AM   #1
BurnSlowly
Drives: 2013 Camaro 2LT (SIM)
Footwell Lighting Help!!
I need help connecting my footwell for my passenger side.
Driver side was a breeze to install. When I try connecting wires to my passenger side it won't light up. Please help me!
Driver side: Quick spliced positive(red) wire to the GRAY wire that is underneath the gas pedal. Then I got a spade terminal and grounded the negative(black) wire to the bolt near the center console. This part was easy and works without a doubt with my dome lights!
Passenger side: Quick spliced postive(red) wire to the DRIVER positive(red) footwell wire. Then I got another spade terminal and grounded the negative(black) wire to the bolt near the center console.
For test taking purposes I didn't put passenger footwell in the passenger side. It was still on the driver side. Basically two ground terminals on the bolt. The driver side footwell works because even when I touch the bolt with the terminal it lights while the passenger one doesn't.
Driver side is fully done and doesn't need modifications. I just need to know how to connect the passenger footwell. Please help! because right now I'm just rocking one footwell
BTW: I tested two light strips. I doubt it is both defected.
BurnSlowly is offline   Reply With Quote
Old 01-17-2014, 08:03 AM   #2
timppg
Drives: 2011 ss synergy green
I just tied my passenger side in to the drivers side for the hot and ground wires. Mine works great.
timppg is offline   Reply With Quote
Old 01-17-2014, 10:23 AM   #3
sjmautoprod
sjmautoprod's Avatar
Drives: '16 2SS
Likely a bad or reversed connection.
sjmautoprod is offline   Reply With Quote
Old 01-17-2014, 10:57 AM   #4
SgtPickles69
Team LFX
SgtPickles69's Avatar
Drives: Fast
-Make sure your light strip works
-Recheck connections
SgtPickles69 is offline   Reply With Quote
Old 01-17-2014, 11:37 AM   #5
Jalberdi99
Jalberdi99's Avatar
Drives: 2014 Summit White 2SS/RS M6
this,
what i did was, i made the 2 red(+) from light strip into one then spliced into the dome light (grey ) wire
Jalberdi99 is offline   Reply With Quote
Old 01-17-2014, 11:05 PM   #6
Wollmank
Drives: 2014 Camaro 2SS/RS 1LE AGM
Some led strip lighting are reversed. Switch pos and negative.
Installed many.. Same brand, bought at same time. Still one was reversed.
Hope that helps.
Wollmank is offline   Reply With Quote
Old 01-18-2014, 01:02 AM   #7
Knockoutpie
Knockoutpie's Avatar
Drives: 2014 2SS RS Coupe
Easy fix
The way I did this In 2 Camaros so far is I put both red wires from each led strip, crimped those together, then put a wire from the end of that crimp to the gray wire under the dash, next I grounded both the wires to the same bolt, I can almost gaurantee it's because you tried to tap into the red power wire for the driver footwell, seriously, don't do that.
The power wire on the led strip is so small that your tap simply just isn't touch it.
Knockoutpie is offline   Reply With Quote
Old 01-18-2014, 01:10 AM   #8
JewelSS
Norcal Camaros
Drives: 2010 Red Jewel 2SS L99
Originally Posted by Knockoutpie View Post
Easy fix
Agreed and problem solved ^^^^^^
JewelSS is offline   Reply With Quote
Old 01-19-2014, 04:45 AM   #9
BurnSlowly
Easy fix
Thank you Now it's looking good! Only reason I tapped the passenger red to driver red was because my red wire was short. So I extended it. I also made both ground into one terminal. Basically did everything your way! Thanks a lot!
Old 01-20-2014, 12:40 PM   #10
Knockoutpie
What color footwells did you put in?
Old 06-03-2014, 10:21 PM   #11
Daltronic
Daltronic's Avatar
I'm having same problem I put the two red cables spliced them together into one wire then from that went and t taped the grey wire and I put the two blacks together on the bolt everyone talks about and still no dice any other ideas ? drivers side works perfect so im not sure what else could be problem simce didnt splice into the light power wire
Daltronic is offline   Reply With Quote
Old 06-03-2014, 10:27 PM   #12
sjmautoprod
Drives: '16 2SS
Red t-tap?
Ah. Just saw your note about driver side working.
Old 06-03-2014, 10:32 PM   #13
Daltronic
Daltronic's Avatar
yea tha's why im confused and I think its a blue t tap actually it came with it from phastek
Old 06-03-2014, 10:33 PM   #14
sjmautoprod
Drives: '16 2SS
Yeah, blue is too big, but, that does not explain the passenger side.
blue, footwell, lighting
