Old 07-22-2009, 11:58 PM   #1
Jozef
Drives: 2010 1LT Black on Black
Clicking in the Dash
Does anyone have a clicking in their dash when they remove the key from the ignition? I have this happen every so often... Not always, but enough to make me wonder. As soon as I turn the key, everything stops.
It's a very quiet clicking... Any ideas?
Jozef is offline   Reply With Quote
Old 07-23-2009, 05:59 PM   #2
Quackaddict
Quackaddict's Avatar
Drives: 2010 1LT/RS Black on Black
no but I will listen for it tonight and let you know.
Semper Fi,
Kevin
Quackaddict is offline   Reply With Quote
Old 08-02-2009, 10:45 AM   #3
CamaroBAMF28
Drives: Black 2LT RS
the only thing that i hear is when i turn the car off, and i get out it sounds as if a tiny ball dropped or something. i dont think its anything bad
CamaroBAMF28 is offline   Reply With Quote
Old 08-02-2009, 12:24 PM   #4
Jozef
What you hear is probably the heat shields surrounding the exhaust under the car shrinking as they cool down. A lot of times is sounds like clicking, but it's really just the brackets and or clips holding it in place shifting...
My sound is coming from behind the gauge cluster, and of course the dealer wasn't able to recreate it.
Old 08-02-2009, 01:18 PM   #5
Ferrarimk13
Ferrarimk13's Avatar
Drives: Hopefully a Camaro in a year
isnt that from the suspension releasing slowly after you shut the car down?
Ferrarimk13 is offline   Reply With Quote
Old 08-02-2009, 01:21 PM   #6
BigBOSS
BigBOSS's Avatar
Drives: 2010 Camaro 1LT/RS, 6M, IBM
Is the time between each click the same?
BigBOSS is offline   Reply With Quote
Old 08-02-2009, 03:23 PM   #7
buddylok
buddylok's Avatar
Drives: -
I hear the exact same sound in my 1LT, like a tiny ball dropped or intake/exhaust valve closing.. you are not alone.
buddylok is offline   Reply With Quote
Old 08-02-2009, 07:55 PM   #8
CamaroBAMF28
also another thing is that when i try to rip through the gears, shifting into second....sometimes it doesnt go into gear it just grinds. anyone know what's up with that?.....
Old 08-02-2009, 09:59 PM   #9
Jozef
Are you using your clutch?
Old 08-02-2009, 10:00 PM   #10
Jozef
The clicking is very rapid- and is coming from behind the gauge cluster...
Old 08-03-2009, 12:30 AM   #11
CamaroBAMF28
yes im using the clutch haha.
Old 08-03-2009, 12:39 AM   #12
Parker
Parker's Avatar
Drives: 2010 Camaro SS/RS
Is your door open when you do this? Also are cycling the key out rapidly? It might be RAP system venting. My current car doesn't have one, so i don't quite remember the sound it makes. It should be some kind clicking as a few relays go off near the same time.
Parker is offline   Reply With Quote
Old 08-03-2009, 05:53 AM   #13
robsmack920
Drives: 2010 2SS #3894
i have a clicking when im driving slow, i sounds like its coming from under the dash in the passenger side, ive tried to figure it out but it doesnt happen all the time... but yes i do to
robsmack920 is offline   Reply With Quote
Old 08-03-2009, 10:34 PM   #14
az5thgen
az5thgen's Avatar
Drives: 2010 1LT
I hear the clicking about 2 seconds after I get out of the car. Sounds like a relay shutting off or something. Definetly not the heat shield pinging, this is a mechanical sound.
az5thgen is offline   Reply With Quote
Intermittent clicking noise at low speeds I8A4RE Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 11 01-07-2015 05:30 PM
Dash gauges not working and clicking noise Tigerrag24 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 26 02-26-2013 03:16 PM
Blue lighting on the dash gauges? bluecamaroguy 5th Gen Camaro SS LS LT General Discussions 18 07-23-2011 03:31 PM
Clicking noise behind instrument cluster - 1995 z28 BamTino024 4th Generation Camaros 1 04-12-2009 08:13 PM
Fabric Dash Trim UCF w00t 5th Gen Camaro SS LS LT General Discussions 13 03-20-2009 09:33 PM
