Old 01-19-2014, 10:51 AM   #1
toddbyrum
Drives: 2013 1LE
Power drops in 6th gear…top speed governed?
I'm already loving this forum…you guys rock! Just bought my 1LE in Oklahoma and driving it back to San Diego. I've been at some pretty high elevation for a lot of the trip (been through Taos NM and took the high road to the Grand Canyon and then down to Sedoan AZ). Yesterday on my way to the Grand Canyon I was on some incredibly killer roads and ran the car pretty hard. Kept her at 120 mph for about 30 minutes straight…no kidding. What I've noticed is that from 120 + acceleration is slow especially in 6th gear. I was able to hit 135 at one point but it felt like it took forever to get there. I've heard these cars have a top speed of 155 mph but I'm not seeing it. Felt like a pig at anything over 120.
When I had the rpm's high in 5th it still pulled pretty strong but as soon as I drop her into 6th…..sluggishhhhhhhhh.
Everything is still stock…I'm thinking a aftermarket intake might help?
toddbyrum is offline   Reply With Quote
Old 01-19-2014, 10:56 AM   #2
SPCBA
Drives: pleather and Chiclets
.... 6th gear loses power and the ability to accelerate. its supposed to be that way. 5th is your top speed gear
SPCBA is offline   Reply With Quote
Old 01-19-2014, 11:08 AM   #3
toddbyrum
Drives: 2013 1LE
so that is how it is designed? 6th gear is nothing more than a gas saving gear….no other use. You are saying that if I want to hit the car's top speed I need to do it in 5th. Just to be clear, I have the 1LE trans…m6060 or something like that.
Old 01-19-2014, 11:09 AM   #4
toddbyrum
Drives: 2013 1LE
"I wanna go fast, I wanna go fast, I wanna go fast"
- Ricky Bobby
Old 01-19-2014, 11:17 AM   #5
SimpleGreen
Drives: 2015 2SS/RS
6th gear is for cruising at highway speed. Just an overdrive gear. You'll notice that there is a significant drop in RPM from 5th to 6th. Shouldn't be using anything higher than 5th to haul ass, lol.
2015 Camaro 2SS/RS SIM
2016 Jeep Wrangler 2DR Willys Wheeler
1993 C1500 Single Cab Stepside 5.3L LS Swap
SimpleGreen is offline   Reply With Quote
Old 01-19-2014, 11:23 AM   #6
VOGGS-LS3-1LE
Angry by Nature
VOGGS-LS3-1LE's Avatar
Drives: 13' Camaro 1SS/RS/1LE/NPP 1 of 76
First manual trans car? Higher rpm = more power. Especially needed at higher speeds. 6th is geared to be a cruising gear. If you want speed run out all the gears....
2013 CHEVROLET CAMARO 1SS/RS/1LE/NPP
1 OF 76
Roto Fab CAI
1LE BADGES
VOGGS-LS3-1LE is offline   Reply With Quote
Old 01-19-2014, 11:23 AM   #7
1Slow6.2
1Slow6.2's Avatar
Drives: 2013 1LE camaro
6th gear is pretty much the final drive of the 3:91 gear ratio. In turn it's basically a cruise gear not going to get much power output from that gear. I've pulled 120+ in fourth gear and it still gives me more. Not sure how these motors are built but you're asking for problems trying to pull those high numbers from that gear. Hence burning up a cylinder prob #8 since it's the furthest away from the the circulation of coolant.
If you're reading this objects In side view mirrors are losing as I'm rowing the 3:91's
1Slow6.2 is offline   Reply With Quote
Old 01-19-2014, 11:24 AM   #8
KY1LE
KY1LE's Avatar
Drives: 2013 Camaro 1LE 2SS,RS,NPP
This may help in understanding what is going on. Both 5th and 6th are overdrive gears, 6th more so than 5th however.
MM6 w/ 3.91
1st gear ratio: 2.66 10.42
2nd gear ratio: 1.78 6.97
3rd gear ratio: 1.30 5.09
4th gear ratio: 1.00 3.91
5th gear ratio: 0.74 2.90
6th gear ratio: 0.50 1.96
KY1LE is offline   Reply With Quote
Old 01-19-2014, 02:45 PM   #9
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
I could never afford a supercharger,but if one were installed,then would she pull in 6th?
cornerspeed92 is offline   Reply With Quote
Old 01-19-2014, 03:14 PM   #10
trackguy
Drives: .....
In a sense, yes. GM is required to meet agreed-upon CAFE targets, and six-speeds with very high sixth gears is part of how they do it. That gear is unrelated to wringing excitement out of the car.
trackguy is offline   Reply With Quote
Old 01-19-2014, 04:19 PM   #11
Msmall143
Msmall143's Avatar
Drives: Camaro
4th gear will get you to 130. When I dyno mine in 4th that's what it hits before reaching rev limiter.
If you only hit 135 you were NOT at high rpm's in 5th, or your shits just broken. From a gear perspective 5th could do 180-190 or so assuming you had the hp and aerodynamics to allow for it.
FYI....driving at 120 for 30 minutes is retarded. Even I push the limits a bit but that's bitch slapping fate in the face and asking for trouble Next time you'll end up with a huge ticket and no license or a reck. You basically bet there wasn't a cop within 60 miles...stupid!
Msmall143 is offline   Reply With Quote
Old 01-19-2014, 06:08 PM   #12
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
These cars have no problem pulling up to that 155 limiter. 4th gear I've hit 132 and hit the rev limiter/fuel cut. 5th still pulls over that.
CamaroDreams76 is online now   Reply With Quote
Old 01-19-2014, 06:18 PM   #13
Rod Knock
Rod Knock's Avatar
Drives: 2003 Dodge Viper/2011 IOM SS vert
..... You basically bet there wasn't a cop within 60 miles...stupid!
Whens the last time you drove open roads (not interstate) out west? You may drive 60 miles and not see another car, much less a cop. That said, personally I do most of my really high speed driving on the track.
Rod Knock is offline   Reply With Quote
Old 01-19-2014, 06:39 PM   #14
vinman
The BBOMG fill-in husband
vinman's Avatar
4th will hit 155 on an regular SS, I've seen it on the dyno, mine hits about 152 in 4th
UPSTATE C5 MEMBER
6th gear slow, after market intake, sluggish top speed
