Old 07-23-2009, 01:33 AM   #1
MustangKillr
MustangKillr's Avatar
Drives: 2010 Camaro 2SS
3.73 gears
Hey everyone, I've got yet another question for you guys. I just recently got my RPO code list again after having it gone after my grandpa (initial owner) got hit on the driver's door and had to get a new door (with no RPO sticker). ANYWAY, I checked the code list and I was noticing I have currently have 2.73 ratio gears on my car and I looking to upgrade to 3.73 for my A4. I found a set on eBay, but it looks kind of sketchy, I wanted some of your input. Thanks !
http://cgi.ebay.com/ebaymotors/ws/eB...=#ht_500wt_955
MustangKillr is offline   Reply With Quote
Old 07-23-2009, 07:51 AM   #2
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
Send a message via Yahoo to TFord
As always, LS1tech will have much more in depth info, but Im sure that you cant just throw in 3.73's because you have a 2 series carrier (ie 2.73), and will need a 3 series carrier. Its been a while since I've did any reading about rear ends. but there are some in depth threads on ls1tech.
TFord is offline   Reply With Quote
Old 07-23-2009, 07:50 PM   #3
shinzon
Night Fury
shinzon's Avatar
Drives: 2014 ZL1
x2
2014 Black ZL1 - Toothless -
Previous Lovers :2014 1LE , 2010 2SS RS,2004 GTO, 2000 Camaro SS x 2
shinzon is offline   Reply With Quote
Old 07-23-2009, 08:01 PM   #4
01pewterz28
#TeamBeckyD
01pewterz28's Avatar
Actually you can add 3.73's to your series 2 carrier you just need to get a set of 3.73 gears that are made for a series 2 carrier.
My 2001 Z/28 had the 2.73's I ordered a set of 3.73's from Summit Racing w/ the proper install kit. All in all I paid around $350 for the gears and install kit plus $300 to have it installed the only thing you will need to do is have the Speedo re-cal.
So far the gears have made a world of difference I found my missed power
Sean
#TeamBeckyD
**FIFTY HBM 2SS VERT**
Old 07-23-2009, 08:17 PM   #5
69 Hugger
69 Hugger's Avatar
Drives: 69 Convertible Camaro
Same here I had 2:73s in my 69 and ordered a set of 3:73's from Richmond, but I added a Eaton posi unit also. I'd double check it, How much?
69 Hugger is offline   Reply With Quote
Old 07-24-2009, 02:02 PM   #6
01pewterz28
#TeamBeckyD
All of my stuff is stock all that was replaced was the gears, and the Motive gear installation kit.
Sean
#TeamBeckyD
Old 07-24-2009, 04:49 PM   #7
7CAMARO7
7CAMARO7's Avatar
Drives: Slow 4th gen
that's what I was thinking. since my car is a m6, I know that it is important to make sure to get the correct carrier style for my 4.10s when I get them. They make different carriers for each gear.
What I would do is make sure to get the right carrier style gears, get gm gears, and order a speedo recalibration tune(with upgraded performance tuning) and I'd call it a day.
7CAMARO7 is offline   Reply With Quote
Old 07-24-2009, 10:24 PM   #8
BunkG
Drives: Chevy Camaro
quick ? what exactly is the point of changing gear ratios? i have a 94 and im looking to add some power as well so is this a good way to go?
BunkG is offline   Reply With Quote
Old 07-24-2009, 11:54 PM   #9
7CAMARO7
7CAMARO7's Avatar
some mods like this will make you faster but not literally add power. Your engine will perform the same as far as hp levels, but it will rev faster because of more leverage against the weight of the car.
a car with a 2.73 will most likely pull kinda soft on the low end of the speedo and pretty damn hard on the top when compared to a 4.10 geared car which will get off the line quicker but will probably not have as high a top speed as the car with the 2.73s
There's always a compromise. Don't get it twisted though, I know guys with 4.10s who can do 150mph easier. I bet past that the pull would slow compared to a 2.73 car, but the 4.10 car would get to about 150 faster. General rule of thumb is 4.10s for ls1 m6 and 3.73 for ls1 a4
Old 07-25-2009, 12:15 AM   #10
Blownhotrodder
Blownhotrodder's Avatar
Drives: 2018 ZL1 1LE
2.73's are pitiful in these cars. I have 3.73's in my 2000 SS m6. They were on the car when I bought it but id say 4.10's would be even better if I was having some installed.
Blownhotrodder is offline   Reply With Quote
Old 07-25-2009, 12:23 AM   #11
BunkG
i bought my car used so i dont really know what all has been done to the car so is there any way of knowing what my gear ratios are?
Old 07-25-2009, 02:13 AM   #12
MustangKillr
Sean
Can you get me a link ? What you described sounds like it would fit all my needs. The carrier, the gears, and everything.
Old 07-25-2009, 02:28 AM   #13
7CAMARO7
7CAMARO7's Avatar
from what I hear the stock '02 Corvettes have 2.73s if they're a4. The other day I showed a 2.73 owner how bad his gears sucked before I got home
Old 07-25-2009, 02:33 AM   #14
MustangKillr
Haha I know what you mean. It never crossed my mind that I should switch out the gears. I was thinking every other mod in the book other than gears lmao. After brakes and tires, my gears are definitely the next thing on my list .
I want 2010 Camaro GEARS! Camaro4466 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 51 12-04-2009 11:39 AM
Rear end gear 3.73 - where to buy? rpepka V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 67 09-17-2009 05:23 PM
Acceleration 2. What gears fit? mmbarberoilman V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 20 05-06-2009 06:37 AM
LS3 + Manual = New Gears? ZZcamaro V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 17 03-16-2009 06:55 AM
Rear End Gears AG454 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 9 11-18-2008 03:16 PM
