Old 01-19-2014, 10:56 PM   #1
Luckyss
Drives: 2010 camaro 2ss
Question Couple questions !
Before I did my cam intake and exhaust. I bought a air raid spacer and jet mas three years ago . Now I got the cam intake and exhaust and thermostat done. And never put on the spacer and mas . I got a tranny tune and of course a e-tune . Question is should I put the spacer and mas on ! Or are they worth shit like I'm thinking ? And by any reason they are worth puting on will I have to get re tuned. Second I'm buying the lsx intake manifold, long tube headers and a throttle body . But I do not know what size to get . 102 mm or the 92 mm? Thanks for the input guys. As I know thes questions have been asked before in the threads . I just wanted to get all the questions out at once .
Luckyss is offline   Reply With Quote
Old 01-19-2014, 11:17 PM   #2
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Throttle Spacer and jet maf would make better paper weights...All of your other mods are sound. I think since you are cammed you can get better gains from the 102mm TB
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 01-19-2014, 11:21 PM   #3
Luckyss
Thanks man! 102 mm not over kill ? maybee ill post the maf and the spacer on craigs list see if I can sell them . lol
There is no replacement for displacement !
Old 01-19-2014, 11:24 PM   #4
Da Mammer
Drives: 2010 camaro SS... shell...
If you are going with the FAST 102mm lsxr intake manifold and a 102mm throttle body your spacer probly won't work anyway. With mine the throttle body is about a millimeter away from hitting the tensioner pulley. No way a spacer would fit.
tried LSXTC...now I'm LSXOD...
Da Mammer is offline   Reply With Quote
Old 01-19-2014, 11:24 PM   #5
Luckyss
I like how you went with the "CUSTOM 2.5" MANDREL BENT EXHAUST" I did the same thing .. 3 seemed to much .
Old 01-19-2014, 11:27 PM   #6
Luckyss
Originally Posted by Da Mammer View Post
If you are going with the FAST lsxr intake manifold your spacer probly won't work anyway. With mine the throttle body is about a millimeter away from hitting the tensioner pulley. No way a spacer would fit.
I don't know why I bought it neways .. guess I had a brain fart. I don't understand what it does but heat more air and or disrupt to flow ! I mean I don't have a Honda .
Old 01-19-2014, 11:27 PM   #7
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
If you weren't cammed it would be. Also, If you decide to do heads in the future, you'll be glad you went 102
Old 01-19-2014, 11:30 PM   #8
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Yeah havent read about any real gains at 3" and n/a, so 2.5" flows good enough
Old 01-19-2014, 11:33 PM   #9
Luckyss
yes im doing it all at once next month . long tube the lsx and I the throttle body all at once. im only short the throttle body. I do not want to get a tune more then once . I do not like my car on the dyno . I have seen cars blow up and do not want mine too .
air raid, jet mas, spacer, throttle body, tune
