Old 01-20-2014, 01:25 PM   #1
2011*Camaro*SS
2011*Camaro*SS's Avatar
Drives: 2011 Camaro 2SS/RS Vert
Continental or Nitto?
I need to decide this soon... Which is the better tire overall?
Nitto Motivo or Continental ExtremeContact DWS
Continental: http://www.tirerack.com/tires/tires....r=RS%20Package
Nitto: http://www.discounttire.com/dtcs/fin...634&vid=020300
Price isn't really a big deal, I have a friend that will get the best price available. I have been looking for too long and am in need of new rears, but ill be replacing all 4.
Thanks for your opinion!
2011*Camaro*SS is offline   Reply With Quote
Old 01-20-2014, 07:39 PM   #2
Houston 45th
Houston 45th's Avatar
Drives: 45th 2LT/RS
I just got new tires also and i was in the same situation you are in. I went with the Nittos because they had a better warranty from discount tire and i liked the tread pattern over the DWS.
2012 45th 2LT RS, LG ZR28 (20x10 20x11) 275/40/r20 315/35/r20, MRT V2.0, Black bowties, MGP Caliper Covers, 15% Tint all around
Houston 45th is offline   Reply With Quote
Old 01-20-2014, 11:16 PM   #3
ex-SS-ve
ex-SS-ve's Avatar
ill have to post up the pics of my continental dws tires. I ended up going with them as I wanted a good looking tire that matched in 275 & 315 sizes.
ex-SS-ve is offline   Reply With Quote
Old 01-21-2014, 01:00 AM   #4
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
Conti
-John S.
Old 01-21-2014, 01:30 AM   #5
ex-SS-ve
ex-SS-ve's Avatar
Side shot
Old 01-21-2014, 01:31 AM   #6
ex-SS-ve
ex-SS-ve's Avatar
One more
Old 01-21-2014, 07:10 AM   #7
jmelchio
SSmokinJoe
jmelchio's Avatar
Drives: 2010 SIM 1SS/RS M6
I got about 40,000 miles out of my Continental DWSs. I use my car as a daily driver. I liked the tires. They were relatively quiet, good traction, and good tread life.
1SS/RS Silver with Black Rally Stripes.
35% Tint
Roto-Fab CAI
SLP Loudmouth II Axleback
Hurst Shifter
R1Concepts Slotted Rotors
Hawk Ceramic Brakepads
I drive way too fast to worry about my cholesterol.
jmelchio is offline   Reply With Quote
Old 01-21-2014, 10:11 AM   #8
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
In a test I saw, the DWS's ranked just below the Pilots in overall performance. They have lots of sizes available as well. I'm running 295/40's in the rear and 255/45's in the front, all on the OEM 20's. They look perfect on the wheels, with just a very slight bulge. My thinking is, they help protect the lip and the extra sidewall softens the ride a tad (I have 1.25in drop springs). They were actually cheaper than the OEM size DWS's. I've driven in rain, sleet and snow and they flat out work. There are better tires for specific purposes but not many for all around performance. FWIW, tirerack is about $20/tire cheaper on the DWS's.
I'm not saying they are better than the Nitto's cause I haven't used them or heard of anyone using that particular tire.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 01-21-2014, 11:10 AM   #9
2011*Camaro*SS
Wow! Thanks for all the replies! My main concerns and the reasons im not getting the pirellis are tread life and sound. Sounds like everyone likes the Conti's, i've asked a lot of different tire places too, but the Nittos are fairly new so that might have some effect. I like the warranty on the Nittos, but I like the look of the Conti's. I want to keep the performance look, but enhance ride and sound. Thank you for the pictures ex-ss-ve!
Old 01-21-2014, 11:14 AM   #10
2011*Camaro*SS
Will you post some pictures? So I can see if they look sporty enough? Thakns!
When you replaced, did you stick with the Conti's? If not, what did you switch to?
Old 01-21-2014, 04:39 PM   #11
firedruish
Guest
Posts: n/a
I will be buying my nitto motivo in two months and i have been researching for a long time...they are for a 11 rs...and I'm a flat out aggressive driver. What I have found is this...The utrg on the continentel is 480 and nitto is 560 which makes for potentially longer tire life. ..less sticky as they are harder. Also reading other forums and on tirerack...There are those customers that say the continental loose alot of performance after halfway point on the tread life. Yes the nitto are new...but so far it's constantly rated a great tire. Tire rack doesn't sell nitto so another source has to be found. Big O tires is a nitto dealer and their prices aren't half bad.
Old 01-21-2014, 05:05 PM   #12
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
I have almost 24k on mine. They are awesome all-seasons. Very good cold weather grip, even better grip in snow & ice. I couldn't move my car with the stock PZeros, but I've driven the Conti's in as much as 4" of snow without problems.
The only downside is they give up a bit of grip during the hot summer months. I'm considering going with a 2nd set of rims/tires for summer use and keeping the Conti's on my stock rims for Oct-March use.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 01-22-2014, 05:44 AM   #13
jmelchio
SSmokinJoe
jmelchio's Avatar
I replaced the Conti's with General G-MAX AS-03s, but it was only due to cost. I put a lot of miles on my car, so I tried the less-expensive tires this time. If money were not an issue, I definitely would have bought the Contis' again.
I actually bought a set of slightly used Conti's for the rears. As soon as the General rear tires wear out, I'll put the used Conti's back on.
35% Tint
Roto-Fab CAI
Hurst Shifter
Old 01-22-2014, 07:44 AM   #14
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
My winter tire in the Conti Extremes. Love them for the cold, wet traction.
