Old 01-22-2014, 12:17 AM   #1
Lvz2881
Drives: 2014 2SS 6SPD
shift point and rev limiter.
Taking my '14 SS to the track Friday night. I'm new to the car and.not.sure what the shift points are on this? It's a manual trans car.
Also, where does the rev limiter kick in on these things?
James
2014 Camaro 2SS 6Spd, Black/Charcoal leather
MGW, JDP Clutch Reloc, Hill Start Assist deactivated, APEX catch can, Muffler Delete, BMR rear arms, links and bushings awaiting install..
1995 Trans AM, M6, 6spd
1980 Malibu, LS Turbo build on the cheap!!
Lvz2881 is offline   Reply With Quote
Old 01-22-2014, 01:48 PM   #2
Dfault
Dfault's Avatar
Drives: 2014 Camaro SS
I ran my 12.9 shifting at about 6,000 rpms. The only mod I had done to my car was the muffler delete and that's about it.
If you're going to good times, don't be afriad to maybe break something in the car. M6 isn't really the best platform to be doing the 1/4 mile in, but we can. Just remember, you're shocking the drive train every time you launch hard.
I don't care if I break something like my rear end or transmission because I'll just fix it myself.
If you don't care, then just use launch control and also slam the gears every time you shift without releasing the gas pedal.
Dfault is offline   Reply With Quote
Old 01-22-2014, 01:53 PM   #3
Lvz2881
Ok. Next question. How do Activate Launch Control?
James
Old 01-22-2014, 02:50 PM   #4
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
While the vehicle is stopped you press the traction control button twice. Your TC light and Stability light on the dash will light up, you are now in competitive mode. Simply hold the clutch in and press the accelerator peddle to the floor. This will limit your RPMs to approximately 4000-4200, this is launch control.
HOJO is offline   Reply With Quote
