Old 07-23-2009, 12:37 PM   #1
rodimus prime
Drives: Cargo van.
Engine cover = giant heat trap?
I parked my car at about 4:30pm yesterday after a few minute trip home from work. No wot or beating on the car. I came out at about 8:30ish just to mess around. I decided to check out the engine cover and what not. Well I noticed that the motor was still extreamly hot for sitting for about 4 hours. I dont remember it taking this long for my 4th gen to cool down to a reasonable temp.
If I had a laser temp gun I would of gotten some temps of the top of the cover and under the cover plus the intake manifold weight. The engine cover even has an insulator pad on the underside.
Anyone think that a CAI would benifit better if the manifold wasnt covered?
rodimus prime is offline   Reply With Quote
Old 07-23-2009, 12:45 PM   #2
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
Maybe the cover should be seasonal?..
Old 07-23-2009, 12:50 PM   #3
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Not sure, but I removed my cover the 1st day I had the car
Crowley is offline   Reply With Quote
Old 07-23-2009, 12:52 PM   #4
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
The engine cover can be easily removed, I keep it on because it does look a lot better than the mess of wires underneath..
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 07-23-2009, 12:52 PM   #5
coolman
Guest
Is there any real reason for the cover other than to dress up the engine bay?
coolman is offline   Reply With Quote
Old 07-23-2009, 12:55 PM   #6
Z_Rocks
Z_Rocks's Avatar
Drives: everyone crazy...
Especially if you park your car in the garage and close the door, where there is no air ventilation or cool air to cool the engine. I've seen people having electrical problems when the car sits in the garage very hot and the wires begin to crack.
If it's parked outside it gets fresh air and breeze, but for in garage, I'd open the hood to let the heat out.
Z_Rocks is offline   Reply With Quote
Old 07-23-2009, 12:57 PM   #7
rodimus prime
Drives: Cargo van.
Think about like this. Your spending up to $500 for a cai. Some of them grab air from the engine bay, others do not. They both as of right now make about the same amount of power on a dyno. Then look at the big baffles on the stock intake. The only thing all the aftermarket intakes have in common is the baffles are removed, therefore making a continuious smooth airflow path to the TB. Then once the air hits the manifold (that is hot from engine operation alone) it is again being heated probably more so than by not having a cai in the first place. Because the air now travels down individual runners instead of one big opening.....meaning easier to soak up any heat the manifold has built. Think of it like a heat sink to dissapate heat. So to make matters worse we trap the heat to the manifold instead of having cool air to help keep intake temps down.
So I guess what Im getting at here is that I think the CAI only real benifit is the removal of the baffles. Hence the reason the OTR intakes....and under hood intakes....and underhood intakes with a separation plate are all making the same power. That air is just being instantly heated by the manifold.
Im just speculating here, but When I find my temp gun I will take some samples of intake temps with the cover off and on.
Old 07-23-2009, 12:58 PM   #8
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
The Corvette LS3 does not have that mess of wires, why does the Camaro?
Old 07-23-2009, 01:01 PM   #9
Supermans
Supermans's Avatar
The Vette also has an engine cover.
Old 07-23-2009, 01:04 PM   #10
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
That mess of wires looks a whole lot better than the ugly engine cover
Crowley
Old 07-23-2009, 01:04 PM   #11
rodimus prime
Drives: Cargo van.
Yeah, but it doesnt cover the intake. It lets it breath.
Old 07-23-2009, 01:06 PM   #12
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
I believe there are 2 covers on the intake .. the big one and then the small black one which is underneath. Does the corvette not have the small black one?
I believe the black "intake part" you see is also a cover .. right?
Crowley
Old 07-23-2009, 01:09 PM   #13
Supermans
Supermans's Avatar
Crowley
I know that to enthusiasts the engine cover doesn't look all that good. However in comparison to this Chevy 427
Which does not need an engine cover but the wires are placed in an even manner looks a whole lot better.. Most people I show the engine to have no idea that there is an engine cover there but are more impressed by the large engine cover than when I show people with it off..
Old 07-23-2009, 01:09 PM   #14
Cam10RS
Cam10RS's Avatar
Drives: Camaro 2LT RS
Engine heat
If the cover has no heat vents for air flow, this would tell me that the wiring will dry and crack at a faster rate, and this would cause the engine to run at a higher temp. and cause a combustion problem later on with carbon build up.
Tell me what u think
Cover looks great on the engine, I will use it only for show.
[SIZE="1"]1100, Preliminary order accepted--3/5/09
2000, Order accepted by GM
3000, Order accepted by production control--8/14/09--TPW(9/14/09
3100, Order available to sequence
3300, Order scheduled for production
3400, Order broadcast-- 09/14/09
3800, Order produced. VIN# 9/22/09
4000, Available to ship
4104, Bailment Invoice
4200, Shipped
4300, Intermediate Delivery
4B00, Bayed
5000, Delivered to the dealer. 9/27/09
6000, Delivered to the customer. 9/29/09
Cam10RS is offline   Reply With Quote
Is anyone else dissapointed by the V6 ENGINE COVER ?? Grandeos Cosmetics and Lighting Modification Discussions 59 11-01-2010 02:13 PM
AirAid Cold Air Intake anyone? FLYNNZL1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 01-01-2010 10:05 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
Axial Vector Engine Mr. Wyndham General Automotive + Other Cars Discussion 6 06-20-2007 05:00 PM
