Old 01-24-2014, 12:21 PM   #1
bionick
bionick's Avatar
Drives: 2010 2SS/RS M6
MPG issue
Okay so my cars average fuel economy on the highway usually says anywhere from around 28 to 32+ miles to the gallon a
With cruise on and randomly now it only goes to 18-20.
What could cause this? Drive on this freeway all the time and it always says about 30
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
bionick is offline   Reply With Quote
Old 01-24-2014, 09:55 PM   #2
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Have you changed anything on the car recently? Or switched to different gas?
Mark114 is online now   Reply With Quote
Old 01-24-2014, 10:02 PM   #3
AKA-22
AKA-22's Avatar
Drives: ELLE-1
weather will effect MPG
AKA-22 is offline   Reply With Quote
Old 01-24-2014, 11:24 PM   #4
bionick
bionick's Avatar
I recently upgraded my stock 18" LT trim wheels to 20x10 wheels with 275/40/20 tires on all corners. Same wheel diameter but wider. Will wider wheels (more tire friction) effect my MPG?
And I know weather effects it but weather hasn't changed much around here lately.
Old 01-25-2014, 08:38 PM   #5
UNRIVALED SS
UNRIVALED SS's Avatar
Drives: 2010 Camaro SS
Send a message via Yahoo to UNRIVALED SS
Wider wheels with greater friction surface is insignificant overall. However, greater unsprung weight could be the culprit. It can tell you it matters substantially.
UNRIVALED SS is offline   Reply With Quote
Old 01-26-2014, 06:29 PM   #6
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
2 summers ago I put larger/heavier wheels on the back of my SS and i lost 4 mph of trap speed in the quarter mile!
I also lost ~50-60km's per tank or there about compared to stock tires. When i switched back to stock tires, gained everything back right away.
But eh, you gotta pay to play!
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
Old 02-08-2014, 11:04 PM   #7
bionick
bionick's Avatar
Maybe I got a bad tank of gas or something because I did the same drive a couple days later and got much better mileage
Old 02-09-2014, 10:43 AM   #8
supasport
supasport's Avatar
Drives: 2010 camaro ss
on a full tank i get 180-220 miles in city
reads 11.5-12mpg
supasport is offline   Reply With Quote
Old 02-12-2014, 02:35 PM   #9
Bagsby
Drives: 2010 Camaro 2SS RS
I do at least 90% city driving and run ethanol free 93 octane. I am averaging around 12.4 mpg. When I got the car it was at 13 mpg. I try to reset my mpg reading everytime I fill up. Could the ethanol free gas be lowering my mileage. I don't dog the car around town but I don't baby it either.
Bagsby is offline   Reply With Quote
mpg
