01-26-2014, 01:39 PM | #1 |
Drives: 13 Black Camaro 1SS Join Date: Nov 2013
Trans help!!
K
01-26-2014, 01:56 PM | #2 | |
Drives: 2010 SS 426 V8 M/T Join Date: Aug 2012
I would take it to the dealer immediately. There are quite a few Chevy dealers in Phoenix. Good luck. |
01-26-2014, 02:31 PM | #3 |
Drives: 2012 camaro Join Date: Feb 2012
are you hard on it? most people who kill their clutch aren't surprised because it takes some pretty abusive driving to do it that fast.
01-26-2014, 05:24 PM | #4 |
old school chevy rodder
your leaking fluid that is exceptionally bad like as in you hitting something on the pan..... Or the internals going bye bye. You better limp it somewhere...with a tow truck as our trans are sealed......... or find the fill and fill it to the point you can pump it up. Ever change your brake fluid? they share the same reservoir if you have not changed the fluid, it could be filthy. The clutch fluid darkens with dirt a lot more than the brake fluid I know I just changed my separate reservoir I installed from a holden that I got on gen5diy here look at this:
http://www.gen5diy.com/moar_powa/clu...-reservoir-kit
2021 Wild Cherry ZL1 A10, Sunroof, Data,Red Carbon Interior, Nav, RotoFab Big Gulp , Elite x2ultra, Borla ATAK, Driveshaft shop, full BMR susp, Speed eng. valve covers, intercoolers, ATI , 2650 MAG, DSX lid, 103 NW, JBA shorties, Lingenfelter check, 1le wheels, spoiler and diveplanes, PCV, Big3racing ice tank, [SIGPIC]etc....
01-26-2014, 05:53 PM | #5 |
JZ
Drives: 2011 Synergy Green Camaro Join Date: May 2011
I wouldn't drive it anywhere and get it to the Chevy dealer Monday ASAP, since they are closed Sundays. These clutches aren't forgiving much on slippage unfortunately. Could be lots of things inside tho, but leaking fluid isn't a good sign tho.
*2011 SGM Camaro*
Hi/low 8k HID kit, Injen WB long tube, Pfadt stage 2, Rx black ice-olator, Rx catch can (color matched =D). |
01-27-2014, 06:06 PM | #6 |
O
