Old 01-27-2014, 07:13 AM   #1
DieselAries1
DieselAries1's Avatar
Drives: 2011 Camaro LS
God awful mileage?
When I first got my car 4 months ago during the summer when I first filled up the display would say approximately 430 miles. Now I am seeing maybe 300-320 at fillup. I have a K&N intake, Mace insulator, and flowmaster exhaust. I removed the terminal from the battery every time also. It's bitter cold up here in the Northeast righ now. Would this affect it. I always allow it to idle down and warm up before going anywhere. It's just 200 miles for 3/4 of a tank is not fantastic. I would think this was about 15 miles per gallon, a 1/2 of what I am potentially supposed to be getting.
DieselAries1 is offline   Reply With Quote
Old 01-27-2014, 07:14 AM   #2
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
The Fuel Range indicator is not always correct.
Have you actually tracked the miles using the odometer?
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 01-27-2014, 07:28 AM   #3
DieselAries1
I usually restart the trip meter at every fill up. I Just so happened to flip it to this screen cause I havn't done it in a while. I was just taken back a little. I did notice that I drove ten miles to work and it went down 1 mile. Maybe I'm being paranoid lol.
Old 01-27-2014, 07:38 AM   #4
Spartan01
Spartan01's Avatar
The same thing happened to me after installing my underdrive pulley and having the computer reset to learn the new pulley. Insteadof the usual "330" miles, the indicator would read "225". But then i ran it against the odometer, and the same thing would happen, I would drive 10 and it would decrease by 1.
Old 01-27-2014, 07:57 AM   #5
james347
Drives: 2006 Crownline
True story. I was having a similar problem with gas milage. The gas pedal was getting stuck to the floor at times. I never find out what was causing it, my foot was always in the way at the time.
james347 is offline   Reply With Quote
Old 01-27-2014, 08:51 AM   #6
DieselAries1
LOL! Yeah that's not the case as it's negative temperatures up here and I have my snapshot from progressive in. I'm on track to take 20% off my car insurance for the summer and then I can drill it lol!
Old 01-27-2014, 08:51 AM   #7
DieselAries1
I'll check it out. If it's not accurate I won't worry about it to much.
Old 01-27-2014, 08:56 AM   #8
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: 2010 SGM Sp. Edition 2017 RS Conver
If using ethanol or a gas anti freeze you can expect a 3-5 mpg decrease. You state that you are allowing warm up of engine, which also decreases your fuel mileage. Add in that it is colder and you will probably see why it is a big difference. I see this happen every winter on my DD.
its a syn is offline   Reply With Quote
Old 01-28-2014, 05:50 AM   #9
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
If you warm up the car for 10 minutes and then drive for 10 minutes at 30 mpg, your calculated mileage is 15 mpg.
Rock-It Man is offline   Reply With Quote
Old 01-28-2014, 06:29 PM   #10
ss/rs/378
ss/rs/378's Avatar
Drives: 2012 ZL1 Camaro Victory Red
You could always sell it and buy a Volt but that would be to boring drive it like you stole it son its a Camaro!!!!!!!!!!!!!!
2.55 UPPER PULLEY,100MM IDLER PULLEY,160 STAT,PORTED TB,PORTED SNOUT,MSD PLUG WIRES,NKG PLUGS,KENNE BELL EXTERNAL FUEL PUMP,2"KOOKS HEADERS,HIGH FLOW CATS,3"CORSA 60LB DEKA INJECTORS TUNED BY FROST 580RWHP,571RWTQ.
ss/rs/378 is offline   Reply With Quote
Old 01-29-2014, 07:30 AM   #11
DieselAries1
I will be for sure but it's hard to do in -15 degree weather. 2 months and I am sure I will go thru a set of tires lol
