Old 01-28-2014, 10:26 AM   #1
MattF
MaroMan426
Drives: 2011 Camaro 1ss
Send a message via AIM to MattF Send a message via Skype™ to MattF
HELP! 2011 SS IN STORAGE FOR 3 MONTHS NOW, NEED TO START?
hello, i have a 2011 camaro ss with a 6 speed manual. it has been in storage in a non heated warehouse in detroit for about 3 months now. it is on the second floor of the building and sits on a wood floor. the building is closed off to the elements. it hasnt been started since october. i am living out of town but will be in town this weekend and have decided to go over and let it run for a while if that is a good idea. i havent put stabil in the fuel, and cant remember how much fuel was in it. the oil was just changed before storing. ive heard both sides of the story to let it sit and to not start it, and people saying to start it and let it run periodically.
MattF is offline   Reply With Quote
Old 01-28-2014, 10:36 AM   #2
meshamey
Meshamey
meshamey's Avatar
Drives: 2011 Camaro 2SS / 2014 Camaro ZL1
Its hard to say At -19 degrees in Detroit right this minute , I would not start it. Its been sitting for 3 months it should be fine.
meshamey is offline   Reply With Quote
Old 01-28-2014, 10:40 AM   #3
MattF
MaroMan426
i plan to keep it stored until april. how long is too long without starting?
Old 01-28-2014, 10:45 AM   #4
Devryn17
Suffers Fools Poorly
Devryn17's Avatar
Drives: 2010 SS/RS, CGM w/ Silver Stripes.
Adding some stabil may not be a bad idea. I can't imagine that cold has been good for it, especially without a block heater. I've never been anywhere that cold, but I would be super paranoid about it.
2010 2SS/RS, CGM w/ silver stripes. Hurst Shifter, long tube headers, full exhaust, CAI, tune. SAE 407 RWHP/402 RWTQ
Momma didn't bronze my shoes, but when I turned 16 I inherited a lead foot.
Devryn17 is offline   Reply With Quote
Old 01-28-2014, 11:29 AM   #5
nelsont
Drives: 2018 2SS Hot Wheels Convertible
No!!!!!!!!!!!!!!!!!!!
Leave it alone. Hope you have a battery tender on it.
The moisture created from starting it is worse for it than letting it sit.
Its metal and plastic not a living thing.
Tim
nelsont is offline   Reply With Quote
Old 01-28-2014, 11:38 AM   #6
EMB135Driver
Jedi Master
EMB135Driver's Avatar
Drives: Boeing 757/767+2010 IBM 2SS
Leave it alone......unless you're going to drive it and get it up to full operating temperature (not going to happen at Idle in a warehouse) its best to leave it alone.
EMB135Driver is offline   Reply With Quote
Old 01-28-2014, 11:48 AM   #7
MattF
MaroMan426
thanks guys, the battery is disconnected currently i do not have a charger for it. also it is locked so i may have to open it with the key and climb through the back seat to release the trunk from the inside when the time comes to re connect the battery and start her up in the spring.
Old 01-28-2014, 11:56 AM   #8
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Probably wouldn't have hurt to fill the tank and use Stabil before putting it away. Aside from that, just leave it alone. It will be just fine when you're ready to get it back out. As for it being -19 in Detroit right now, maybe with the wind chill. It was never that cold at noon in the 10 years I lived there.
Old 01-28-2014, 12:21 PM   #9
Swacer
Drives: 2018 GT350
Leave it sit with the battery tender.
Now, I started my car a week ago after I was trying to determine a vacuum leak that had been bothering me since I put the car away in November.
I let it sit there idling for ~15 mins. At that point, the coolant showed normal temp and the oil showed normal temp.
Off to the Dark Side
Swacer is offline   Reply With Quote
Old 01-28-2014, 12:29 PM   #10
Bumblebee2012
Bumblebee2012's Avatar
Drives: 2012 2SS TF3, 1971 Chevelle
My opinion is that with the current temps in that area, and the slow rate that oil would circulate at that temperature.... unless it was a dire emergency, I would not start it. If it needed moved a bit, I would rather push it around than start it. You'll do thousands of miles of internal wear in those few moments after starting an engine that has been setting that long (fairly dry of oil) while the parts get spun back to life and your waiting for proper oil circulation. Bottom line, do not start it unless the situation leaves you no other choice.
Bumblebee2012 is offline   Reply With Quote
Old 01-28-2014, 12:35 PM   #11
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
Global warming... makes it colder.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 01-28-2014, 02:39 PM   #12
RollaMo
RollaMo's Avatar
Drives: 2017 2SS
Tim
I agree with these.
Unless you can actually drive the car and get everything up to full operating temps, then just leave it alone.
To be honest, 3 months really isn't that long to let one sit.
If you were going to store it for a year or longer, then you might want to look at it differently.
1996 Corvette - LT4
2017 Camaro 2SS
2019 GMC Sierra 2500 HD
2015 Harley Davidson Ultra Limited
RollaMo is offline   Reply With Quote
Old 01-28-2014, 03:05 PM   #13
OHIOSS
Russ
Drives: Yukon Denali, Charger, CamaroSS
Send a message via AIM to OHIOSS
There is about 100 threads about this, you may want to do a search.
I have kept mine in storage for the 4th year in an unheated building and I fill it up before I put it into storage and nothing else. The only reason I fill it up is because fuel is usually cheaper when I put it into storage than when I get it out in the spring.
The car starts like I just put it into storage the day before. I don't use a battery tender or anything else. The tires do get flat spots on them but they go away within a couple of miles.
Russ
OHIOSS is offline   Reply With Quote
Old 01-28-2014, 04:02 PM   #14
MattF
MaroMan426
thanks everyone. i will be sure to leave it alone for now. ill wait until the temps are higher in march or april when i pick it up and drive it back home to wisconsin where i currently work.
