Old 01-28-2014, 08:19 PM   #1
73duster
Drives: 2010 camaro ss automatic
How much horsepower am i going to lose?
I just dropped off my 2010 Camaro at a shop in order to swap out my current flowmaster cat back, for a Corsa catback. I just realized that the Flowmaster cat back is 3", while the Corsa is 2.5".
My car currently puts down 420 HP to the rear wheels with longtube headers, cam and tune. Am I going to lose a noticeable amount of power?
73duster is offline   Reply With Quote
Old 01-28-2014, 08:22 PM   #2
mydreamcar
My Dream Car
mydreamcar's Avatar
Drives: 2011 SIM LS3 1SS
Exhausts are usually for sound, if you lose anything it would be minimal at best
CAI intake/ADM Scoop/Stainless Power Headers/Dynatech cat back exhaust/Vitesse Throttle Control/ Ported Throttle Body/QTP Electric Cutouts/ 3.91 gears and janetty rear posi/ Tuned by Janetty racing
mydreamcar is offline   Reply With Quote
Old 01-28-2014, 08:47 PM   #3
Denis
Denis's Avatar
Drives: 2010 SS
Zero.
Dyno shows that cat backs don't do jack for these cars aside from sound.
Old 01-28-2014, 08:49 PM   #4
Juiced1
Drives: 2012 2SS CAMARO 45th
You might actually gain some power. Corsa systems are straight through and generally outflow Flowmaster exhaust system.
Juiced1 is offline   Reply With Quote
Old 01-28-2014, 08:50 PM   #5
73duster
I thought going from 3" to 2.5" would hurt performance.
Old 01-28-2014, 08:52 PM   #6
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
You will lose nothing.
Sent from my AGM, 2SS/RS
FSP tuned: 377/389
Old 01-28-2014, 09:10 PM   #7
14pilot
Original Bumblebee Owner
14pilot's Avatar
Drives: 265hp ZX-14, 500hp Silverado, V-ROD
+1,000,000 you will not lose any power.
#5 - 2010 2SS/RS MN6 ABM #142-Silver Rallys-GFX / Med Titanium
My previous Camaros:
#4 - 1994 Z/28 6M Black over Arctic White / Graphite-Red Inserts - traded
#3 - 1981 Z/28 Bright Blue Metallic / Black - sold
#2 - 1970.5 RS Mulsanne Blue / Blue - endo crashed it and parted it out
#1 - 1967 RS Butternut Yellow w/ Black Bumblebee Stripe-RPO D91 / Parchment-Black - sold
14pilot is offline   Reply With Quote
Old 01-28-2014, 09:13 PM   #8
Explit Player
IG @Brian_ _Self
Explit Player's Avatar
Drives: 2010 Camaro 2SS M6+17'Tesla Model S
Well, you might loose like 1/2 of a hp if any. But probably not because Corsa is alot better at the systems they make vs Flowmasters.
Explit Player is offline   Reply With Quote
Old 01-28-2014, 09:57 PM   #9
usafboy
usafboy's Avatar
Drives: 2010 Silver SS/RS LS3
good news is your car will sound 1000 times better than flowmaster
2010 Silver Ice Metallic Camaro SS/RS LS3
Mods...so far: resonator/muffler delete, tinted everything, '13 shift knob/boot, bowtie delete, PFADT sway bars, CAI intake, Hurst short shifter, JBA cat deletes, BMR trailing arms/outer bushings/steering rack bushing, Bo White ported TB.
Rhino79 Dyno tuned...405 HP/399 TQ
usafboy is offline   Reply With Quote
Old 01-29-2014, 07:11 AM   #10
jgray1978
Drives: '12 2SS/RS 45th vert, '14 2SS/RS
I think that this would only be a factor if you were FI.
jgray1978 is offline   Reply With Quote
Old 01-29-2014, 07:52 AM   #11
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Unless you are talking about forced induction, cat backs have very little impact on the dyno on these cars. Also the Corsa is much less restrictive than the Flowmaster muffler design so it would probably be a wash anyways. I would only expect a change in sound.
Old 01-29-2014, 08:25 AM   #12
Schluney
Schluney's Avatar
Drives: 2014 2SS 1LE
2.5 corsa will support a lot of horsepower/flow the restriction on these cars is the exhaust manifolds/down pipes with cats
14 2SS RS 1LE Recaro NPP Pat G cam and tune, Trick flow heads Long tube headers catless
Schluney is offline   Reply With Quote
Old 01-29-2014, 08:28 AM   #13
ssmike
BL1ZZRD
ssmike's Avatar
to all of the above! Go for it!
Old 01-29-2014, 12:47 PM   #14
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
That would be true if you were utilizing the extra girth of the exhaust. Fact is, 2.5in is MORE than enough to support mild to moderately modded LS3's. One you start moving some serious air, moving to 3in will start to shine.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
